Question about Weedeater Excalibur Gas Hedge 22" Trimmer Blade
Weedeater Hedge Trimmer
It dies after 5 minutes of operation and where do you add oil. Thanks This is a Weedeater Excalibur 22
It's a 2-cyle engine. The oil is in the gas.
Posted on Jun 09, 2010
Engine backfire
try fresh fuel then take apart the carb and clean it
Mar 24, 2012 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I have an weedeater 22"
check the fuel
if old -- TOSS it OUT!
Fuel quality sucks and has ethanol,. which eats rubber hoses and leaves residues through the carburetor and more,. try wiggling the needle valve without turning it - if otherwise do not loose placement of where the needle valve is setting currently if you do turn or remove the needle valve for inspection..
Also try some starting fluid to blast it a bit,. be careful if it is 2 cycle as you need oil to run the engine too!
Best regards
ck
Aug 18, 2011 | Garden
Engine runs great, accelerator responds perfectly, but the blades stopped moving. Any ideas?
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
Apr 30, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Hedge trimmer put away for winter. will run but not stay running. put in new diaframs for carb . same results. i am questioning the gas cap now. is it possible that it can cause a problem with keeping this...
YES, this system relys on pressure and the ionic nature of gasonline to pull the fuel through the system. If the gas cap is off or damaged where a seal is no longer possible, try taping it up with duct tape and see if that helps
Jun 03, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Weedeater Excalibur Gas Hedge 22" Trimmer Blade Logo
845 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
