Question about Audiovox Bosch 718 World Cellular Phone
I have a Bosch PHO 25=82 750 W plane can you give me instructions on how to change the blade. Thanks
How to fit bosch PHO 15-82 planer base plate
my 15-82 has only one blade.There is a plate with three allen bolts to undo.Under that are two more allen key bolts to to undo.The blade moves although these two bolts are tight.The plane when looking at the drum has 6 inline holes.
Dec 17, 2012 | Bosch Tools & Hardware - Others
How the h... do i cabnge the blade on the bosch 1582 cutter ??
I am assuming you are asking because you have a CLIC system.
Bosch uses a tool-less blade changing system for its jigsaws that it calls "Clic." The system makes changing blades fast and simple. With the simple blade changing you get with the Bosch jigsaws, it is no problem to change out a dull blade.
REMEMBER: SAFETY FIRST LAST AND ALWAYS!!!
Make sure the saw is unplugged or the battery is removed.
If you have a blade in there:
Hold the saw over a work bench and push the ejector lever to the center of the front of the saw. There is a center stop; you will feel it. The blade will eject and fall out
Insert the new saw blade into the plunger until it latches into place. The teeth should face toward the front of the saw. The back of the blade should rest in the groove of the guide roller. The plunger and the guide roller are between the body of the saw and the plate
If the blade will not go into the plunger, check the positioning of the slots in the blade. They should be at the top. Push the ejector lever and try again.
Give the blade a yank to check that it is firmly seated. Plug the saw back in or replace the battery and proceed with the cut
Use protective gloves when handling blades. They can be sharp and can be HOT.
I hope this helps
Please rate FIXYA
Thanks
Charly
May 20, 2011 | Garden
I have a Bosch 1587 avs. I am trying to change the blade. I have followed the instructions as per Manual. In the last part I am supposed to hear a click to lock the blade in to position while rotating the...
First unplug tool and lift up on the knob and loosen the spindle lock, insert blade and push up slightly while doing so and twist to align blade with the roller, while lifting up tighten the knob until you hear it click and the blade should be tight and stay in place. Let me know if you need more assistance.
Apr 04, 2011 | Bosch Saws
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Aug 27, 2008 | Bailey Stanley 12-920 - Block Plane
Audiovox Bosch 718 World Cellular Phone Logo
226 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
