Question about Dell Latitude D600 Notebook
Laptop wont charge
When i plug the charger for my laptop into the wall the green light on the charger turns on, but as soon as i plug it into the laptop the green light immediately turns off. What is the problem and how do i fix it?
    Scholar:
  • 97 Answers
Remove the battery and try again. If it solved the problem the battery is shorted and must be replaced. Look at the plug in the back of the laptop for the power. Is it lose? if it is lose you have a short from it touching contactd together and it must be replaced. If neither of these work try using a loner power supply to see if it is that. The D600 has lots of Power problems on of witch is the Motherboard itself. Hope this helps you out.
Posted on Jun 07, 2010
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
When I plug my acer laptop charger into the wall, the green light lights up accordingly. when i plug it into my laptop the greenlight begins blinking and my laptop does not charge. is something wrong with...
The solution for this problem is the "Mosfet" located near the daughter board of the laptop. just replace the "Mosfet" with new one and you laptop will start charging the battery.
Nov 16, 2010 | Acer Aspire 4720 Notebook
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
May 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
Acer aspire 3680 laptop will not charge while plugged in wall
It appears that you have faulty laptop power connector socket.
This is why it appears to work sometimes when you plug the connector into the laptop in some direction.
To confirm this, wriggle the connector while you look at the charge light on the laptop, if it blinks as you wriggle it then the power socket is either faulty or just needs resoldering so it will make proper electrical contact.
You can get a compute techo to do this or you can do it yourself but it requires dismantling the laptop completely to get at this power socket.
Jun 01, 2009 | Acer Aspire 3680 Laptop
Dell Latitude D600 Notebook Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
