Question about Sony KDF-42WE655 Television
HDM1 input-how to program. Connecting Sony Blu-ray to Sony tv
  • 91 Answers
You should be able to select the HDMI input by running thru with the input button on the remote.......otherwise check the add and delete menu to see if the input has been erased.........you also may have to un plug and plug set in to recognize the new device........an owners manual will give you exact details and there are many sites on the web to down load one if you do not have one
Posted on Jun 06, 2010
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
Connecting blu ray dvd player
You must change the input to the one the blue ray is plugged into, should be labled on the tv
Mar 15, 2016 | Dynex Televison & Video
How should hdm1 cord go between tv and DVD player
If the dvd player has an hdmi output, insert 1 end of the cable there and the other end of the cable insert it behind the tv into the hdmi input. Just make sure that both dvd and tv have hdmi to hook up both together .
Oct 16, 2014 | Sony Televison & Video
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Sony BDB S1100 not connecting to Toshiba TV
Use a good HDMI lead and make sure you select the correct input on the TV.
Feb 19, 2014 | Sony BDP-S1100 Blu-ray Disc Player - 1080p...
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
Jan 02, 2011 | RCA F25645 25" TV
Cannot see video after connecting lg42lc2d with
If you are using the cable for HDM1, maybe the cable it's not good, try another cable or another input on the TV
Dec 23, 2009 | LG 42LC2D 42 in. LCD HDTV
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
Not getting a picture on my sharp 37' lcd 1080p tv
Not sure if you still need help but I will suggest a few things if you have not solved the problem or returned the unit.
Have you tried connecting it to one of the other HDMI inputs?
Have you also tried using the component video out from the Blu-Ray to one of the RCA inputs on the TV to see if the player is working at all? Is there another TV that you can connect it to, to test the player?
Without knowing the model of TV I am limited to solutions I can suggest. Try those and if you need more help, let me know.
Cheers
Dec 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sony KDF-42WE655 Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
