Question about Planar PL2010M 20" Flat Panel LCD Monitor
Planar monitor goes black, what's the solution
  • 11,361 Answers
Check the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 06, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Monitor turns goes black and comes back on every 10 secs planar PX2210MW
The Planar PX2210MW is notorious for bad electrolytic capacitors. Specifically capacitor C804 on the power supply board. . This is a 1000uF 25volt capacitor. That capacitor was usually made by Hermei and it was purple. Normally, the top of a capacitor will be flat. When it fails, it will be curved upward and there may be some brown material leaking out.
If the monitor still will not work after replacing C804, the problem could be Q805 or Q806. These are located on the under side of the board. They are small black surface mounted chips. There are 8 pins on these chips. I have seen both AO4620 and APM4548A part numbers used. These chips contain a pair of MOSFET transistors. One transistor is n-channel and the other is p-channel. Look for a short in one of the transistors. I have repaired several of these monitors. C804 is always bad. How ever, in three cases, Q805 or Q806 was also bad 12c1ec2c-5a6d-4352-af31-150a0a92514c.jpg c9a53aae-2999-45c7-ad78-44ba51ac5a6c.jpg 795d93fe-9678-46c2-820a-767bea9babb0.jpg
Jul 25, 2013 | Planar PX2710MW Monitor
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
I have a PE171 Planar monitor. goes black when turned on
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
Feb 24, 2010 | Planar PE171 (Black) 17 in. Flat Panel LCD...
Planar Monitor Wont stay on
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
Jul 14, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Planar PL2010M 20" Flat Panel LCD Monitor Logo
307 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
