Question about Sony Playstation 3 (PS3) Console
I placed disk in the consule now it want eject what should I do?
    President:
  • 1,194 Answers
Shut off the console with the switch at the back. Press down and hold both the ejection button and the on button. While keeping them held down turn the system back on, but keep the eject button and on button depressed. In a few seconds the console should sound like a vacuum cleaner and the disc should come out.
Good Luck and have a nice day
Posted on Jun 06, 2010
Beeping noise coming from mercury 50hp control consul
Oil Level In Engine Resevoir Is Low If Intermittent
High Temperature If Constant
Re Place Water Pump Impeller Yearly
Feb 23, 2013 | Boating
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
Mar 03, 2012 | Acer Aspire TimelineX 5820T-5951 Notebook
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I have a new ps 3 slimline what do i need to do before removing a ps three game from the consul without causing damage to the consul
if the game is stuck inside,
try hold the eject button for 10 seconds
otherwise you would have to take the PS3 apart
then take the top off of the bluray drive to remove the disc
this will void your warranty though
Apr 06, 2011 | Sony Playstation 3 (PS3) Console
How to eject a floppy disk from the external drive? It is stuck in the drive and can't remember how to get it out.
Sometimes the disk stops when ejecting, and remains in a slightly lifted position, making it impossible to eject it no matter what. It has to come back to it's resting place inside the drive and then you can try ejecting it again.
Try to push it back in with something that will not destroy the disk and the drive, like a piece of cardboard, or your finger, if you can reach inside.When it clicks back into place, try ejecting it again. Repeat a couple of times if necessary, it should unlatch eventually.
Nov 03, 2009 | Iomega (32453) External ZIP Drive
Disk stuck in wii consule
eject button press as many time as you want quickly as possible.
turn off the wii console unplug it and wait for an hour or so
then turn it back on and again to step 1 and pray it the disk comes out....
Jul 11, 2009 | Nintendo Wii Console
Playstation 3 broken!
what probably happened is when you dropped it which why was it dropped in the first place. the track that ejects the disk was probably knocked out of place resulting in the problem with the ejecting of the disk. the only thing that i can possibly think of is to check for screws and open up your ps3 then check the disk ejection system and see what was jumbled around. hope this helps dude.
May 22, 2009 | Sony PlayStation 2 (PS2) Console
Disc stuck inside Wii Consule
Unplug everything from the system and the power cable from the wall or power strip, let it sit for about 5 minutes. Plug everything into the system first then the wall. Power should come on
If the disc does not eject, contact nintendo, the disc drive will need repair
Mar 15, 2009 | Nintendo Wii Console
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Nintendo wii system gamecube game is stuck inside ,everything else still works
    it's the ejectijon button cause i have the same problem but with a wii disc
    Feb 09, 2008 | Nintendo Wii Console
    Sony Playstation 3 (PS3) Console Logo
    69 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
