Question about ViewSonic VX910 19" LCD Monitor
ViewSonic spare part
Where did you buy the power supply? on the internet?
thank
  • 398 Answers
This uses an internal Power Supply and is not intended you user to change it out. This model is covered by a one year warranty, I would contact ViewSonic directly.
http://www.viewsonic.com/support/warranty.htm
If it’s not under warranty the Power supply is what is referred to as “proprietary” meaning that no one (other then ViewSonic) uses this particular power supply. You will have to try to buy it from them. http://www.viewsonic.com/support/
Good luck
Posted on Apr 12, 2008
Viewsonic n2750w blinking screen
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 08, 2017 | ViewSonic Televison & Video
I have a Viewsonic NX1932W Diamani Duo TV. If you turn off the power, when you turn it back on only the audio will work. You have to leave it off an hour or so before the video will start again.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 05, 2016 | ViewSonic Televison & Video
Viewsonic VA1948M no power on
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name "Viewsonic" in the search box at the top right of the display window, to get gathered related posts.
Jun 26, 2015 | ViewSonic VA1948M LCD Monitor
The power on led flashes but no screen
You need to check on the cable that is connecting your computer and the monitor. Usually you encounter this problem when the monitor is not getting any signal from the computer. Try other VGA cables if you have spare monitor in your area.
Let me know how it goes.
Dec 18, 2010 | ViewSonic VA703B LCD Monitor
Where can i get power supply module for viewsonic lcd tv model N3260w
You can buy power supply board/ module of Viewsonic N3260W from Shop Jimmy on special price, $65 only.
Thanks.
Mar 02, 2010 | Televison & Video
My VA712 does not turn on, when supply button (mains) not from front panel, switch ON it shows blank screen (no sign of turn on) but when repeatedly switch ON & Off it Turns On & shows the display....
bholesir, If unit covered by ViewSonic warranty, USE IT!!! The units "switch-mode-power-supply" is in need of service!! Unit WILL require inspection and repair of possible bad (poor quality soldering) soldering of electronic components to the prinded circuit cards and or need replacement of bad (poor quality) electrolytic filter capacitors on the unit's "switch-mode-power-supply"/"CCFL inverter circuit" that have failed!! Do a visit to YOUTUBE for "LCD monitor disassembly" and "LCD monitor repair" so you can familarize FYI with what is inside your monitor, and possibly make a decision to do a DIY repair or contract out the work to a local TV/LCD monitor repair shop. If your pocket is deep enough, maybe you will repair and buy a new unit, keeping VA712 as spare unit for a rainy day. Read more of my responses to other owners in my FIXYA profile for more options not mentioned here. Good luck with repair. 12fixlouie
Jan 27, 2010 | ViewSonic VA712 17" LCD Monitor
Looking for a 715L1075-1-v Ver B power supply
>> 715L1075-1-V1 PC MONITOR - POWER SUPPLY FOR VIEWSONIC N/A TV
Once you have the _correct_ part-number, you can buy it online:
http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/1049626-viewsonic.htm
Sep 19, 2009 | ViewSonic VX910 19" LCD Monitor
Veiwsonic vx912 - ficking on/ off every few seconds
try different video cable or check it, if not power supply.
Apr 21, 2017 | ViewSonic VX912 19" LCD Monitor
ViewSonic N2700 Blinking power button
replace the power supply, buy it on the internet by looking up the model number on the power supply. I have this tv and it did this until I ordered a new one. it runs hot and has a loud fan.
Jun 14, 2008 | ViewSonic N2700W 27 in. HD-Ready LCD...
Viewsonic warranty
I've had several problems with Viewsonic screens, and not only with screens but also with their technical support which would litteraly take monthes to proceed with the replacement of faulty screens.
Two things you should know :
You can find spare power supply cards, it's easy to open the screen and take out the power card so that you can see the reference, usually a card like that costs about 10$, not a big deal for saving the screen
The other thing is that you shouldn't buy Viewsonic screens anymore, there are brands from asia like Hyundai (for workstations) or Samsung for personal use, who have a way better technical support, the best part being that you usually never have to call them :)
Feb 07, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VX910 19" LCD Monitor Logo
237 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
