Question about Crosley CR248 Turntable
What currently available stereo cartridge/dual needle(78* & LP) should I buy for my ancient Soundesign #435 with BSR C129R turntable
  • 821 Answers
Hello,you can visit the link below and pick any of the needles and you can also place your order of purchase from there.
wish you good luck,
take care.
Posted on Jun 06, 2010
  • herbheiss Jun 06, 2010
    WHICH cartridge?WHICH needle? and there was no link indicated
  • Hammid Disu Jun 06, 2010
    hello,please kindly visit this site and you will see the actual cartridge there and you can as well order for it there.
    http://www.styli.co.nz/stylus-102.html
    take care.
How do I replace the needle cartridge?
That does not appear to be a part that is readily available. Contact information is here: http://www.pyleaudio.com/ContactUs.aspx
Oct 09, 2014 | PyleHome VINTAGE PTCDS2UI...
Where can I buy needle for cr73-3
These people can help. Be sure you get the right kind (LP or 78)... http://www.lpgear.com/product/CSYCR0073W.html
You can contact them here... http://www.lpgear.com/CTUS.html
Jul 08, 2014 | Crosley Conductor CR73 Turntable
Just switched my needle on an ION Profile LP but no sound will come out of my speakers.
Disconect the wires to the cartridge. With the amp on touch each wire one at a time with your finger. You should hear on Two wires a buzz- one for each channel. If you do then the cartridge has failed. If you don't then there's either a bad connection to your amp, or the magnetic cartridge pre-amp inside the amp has failed. This will not effect any other part of the amp.
Feb 24, 2013 | ION Audio Vinyl Recording Turntable
What is the replacement needle for crosley cr74
Here i have added two links which will take you to the needle for Croslye CR 74. There you can also fined the code for the item
LP Gear stylus for Crosley
LP Gear 78 RPM stylus for Crosley
Dec 09, 2012 | Crosley CR74 Turntable
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Dec 19, 2011 | Audio Players & Recorders
I have a Zenih Allego table type stereo with 8 track, radio & turntable, but it has NO cartridge at all - just wires from the needle arm. It's supposed to play 78s, how can I find out which cartridge...
You will need a very old type of cartridge called CERAMIC CARTRIDGE or CRYSTAL CARTRIDGE. It has been discontinued. Today's Hi-Fi use magnetic cartridge. Check out this link below
http://www.kabusa.com/frameset.htm?/phoncart.htm
Mar 10, 2011 | Audio Players & Recorders
How do i get it to work? sorry but this is my first time using a record player
most of today's receivers dont have the jacks for phonos...you will be able to plug left/right plugs into aux/cd (unless you are using a power amp) . is your phono equipped with the needle (cartridge) also? yes, then you are ready to play a LP/Album...turn volume down on amp or receiver place LP onto turntable needle on switch source selector to what you plugged into turn vol up slowly and enjoy
Aug 13, 2010 | Aiwa PX-E860 Turntable
I own an AIWA Stereo Synthesizer Tuner which has a 3 speed turntable, double cassette deck and CD player. Just had the CD player cleaned and it works fine but the stylus for the turntable is shot....the...
Unfortunately without seeing the actual needle or cartridge, it is just about impossible to provide you with a part number. Where are you located? Needles are still available and I sell them all the time. I will try to locate the "standard" part number for your model, but there were often different setups available. Is there any way to provide a photo of the one you have now?
Check the balance of the tonearm as well. If there is not sufficient pressure on the needle, it won't track the record correctly either. Please note, the you shouldn't put too much pressure or you will wear the record.
Please keep us posted.
Thanks,
Dan
Sep 21, 2009 | Aiwa Audio Players & Recorders
Crosley CR248 Turntable Logo
43 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
