Question about Raymarine E120 GPS Receiver
It appears in 00 nm - Raymarine E120 GPS Receiver
    President:
  • 1,561 Answers
Occasionally, a GPS unit will need to be reset. This can be due to software errors, firmware updates or simply at the command.
Hold the GPS firmly at arm level. This will help prevent striking the wrong keys as the keypad is very small.
Locate the Light key. It can be identified by the icon of a light bulb on a green background.
Press the Light key for approximately three to four seconds. This will initiate the quick power down sequence. When the sequence begins, release the Light key.
Wait approximately one minute for the gps random on-board memory (ROM) to fully discharge.
Press the green Light key to reactivate the GPS. Wait for the Garmin welcome screen.
Posted on Jun 06, 2010
8D 00 00
When I switch-on "Mammoth" tape drive, the following error appears on the mammoth display " ERR: 8D 00 00". What is the problem and how to resolve ?
Thanks in advance.
Feb 11, 2013 | Tandberg Data Exabyte Exatape Mammoth 8mm...
Error DVD Navigator:AC3
but it doesnt play ac3 file types
Jul 26, 2012 | MSI Computers & Internet
Seat inca van 00 sdi 1.9 diesel.. tension polly came loose.. timing belt slipped.. I need to know how to reset it again. Where are the markings on the crank shaft and the cam shaft? Please attach any...
Timing belt set-up for a 2000 Seat Inca 1.9 SDi
1. Align the crankshaft timing marks on the flywheel / gearbox
2. Remove the valve cover
3. Lock the camshaft
4. Fit the injection pump locking pin
5. Loosen the camshaft gearwheel bolt, 180 degrees. Use a wrench to counter-hold
6. Loosen the camshaft gearwheel while holding it in place
7. Fit the timing belt in the sequence as shown in the below figure: a - b - c - d - e - f - g
8. Fit the timing belt and camshaft gearwheel together
9. Turn the tensioner clockwise to align both marks
10. Tighten the large bolt on the tensioner to a torque of 20 Nm
11. Check for correct fit
12. Lock the camshaft. Tighten the camshaft gearwheel bolts: 45 Nm. Use a wrench to counter-hold
13. Remove helping tools
14. Turn the engine two rotations by hand
15. Repeat the procedure if required
16. Fit the vacuum pump
17. Refit the crankshaft pulley. Tighten torque: 20 Nm + 20 degrees
18. Fit the timing belt cover
19. Refit the valve cover
20. Fit the ancillary drive belt
21. Refit the inlet air manifold hoses
22. Check the injection timing
Torque settings:
Camshaft gearwheel: 45 Nm
Tensioner pulley: 20 Nm
Crankshaft pulley: 20 Nm + 20 degrees
May 26, 2011 | Volkswagen Passat Cars & Trucks
What size torque bit to get brakes off? 1999 expedition
To front pads, tighten the caliper pins to 16-30 ft. lbs. (22-40 Nm) on 1997-98 F-250HD, F-350 and F-Super duty models. Tighten the caliper pins to 21-26 ft. lbs. (28-36 Nm) on the F-150, F-250, Expedition and Navigator. Tighten the caliper pins to 42 ft. lbs. (56 Nm) on the 1999-00 F-250SD, F-350 and F-Super Duty models.
To install the rear disc brake caliper onto the rear support bracket. Tighten the caliper retaining pins on the F-150, F-250, Expedition and Navigator to 20 ft. lbs. ( 27 Nm). Tighten the caliper retaining bolts on the 1999-00 F-Super Duty models to 27 ft. lbs. (36 Nm.)
Hope helps.
May 09, 2011 | 1999 Ford Expedition
Yes i have a 00 model nissian quest van. 3.3 v-6 motor i cant find nobody who knows what the mains and rods torque at. i put a new crankshaft in the van and dont know what to torque the rods and mains at....
main bearing cap bolts: tighten them in three steps, in sequence, to 67-74 ft. lbs. (90-100 Nm).
rods: Lubricate the threads with new engine oil and install the nuts, using the following procedure:
  1. Tighten the nuts to 10-12 ft. lbs. (14-16 Nm).
  2. Using a torque angle meter, tighten the nuts an additional 60-65°. If a torque angle meter is not available, tighten the nuts to 28-33 ft. lbs. (38-44 Nm).
Oct 05, 2010 | 1994 Nissan Quest
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One...
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Nov 16, 2009 | Acer Aspire™ T180 PC Desktop
How to 1998 Taurus altenator R&R
please rate highly if this helps
Generator 3.0L (2V)
Removal
  1. Partially raise the vehicle on a hoist. Refer to Section 00-02 .
  2. Remove the right front wheel. Refer to Section 00-02 .
  3. Remove the lower fender splash shield retainers and position the shield out of the way.
  4. Lower the vehicle.
  5. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  6. Remove the power steering line bracket and heater hose support bracket from the generator.
  7. Remove the upper generator bolts.
  8. Remove the generator splash shield.
  9. Raise the vehicle.
  10. Disconnect the electrical connector and remove the battery positive cable from the generator.
  11. Position an adjustable stand to the subframe.
  12. Remove the right subframe bolts.
  13. Remove the lower generator bolt.
  14. Disconnect the right hand stabilizer link.
  15. Lower the subframe to provide clearance.
  16. Remove the generator.
Installation
  1. NOTE: Do not tighten the lower bolt.
    Install the generator and the lower bolt.
  1. Raise the subframe and install the subframe bolts. Tighten the bolts to 90 Nm (66 lb-ft).
  1. Connect the right hand stabilizer link and torque to 47-62 Nm (35-46 lb-ft).
  1. Remove the adjustable stand.
  1. Lower the vehicle.
  1. Install the upper generator bolts and tighten them to 25 Nm (18 lb-ft).
  1. Install the power steering line bracket and the heater hose support bracket. Tighten the nut to 20 Nm (15 lb-ft).
  1. Install the accessory drive belt. Refer to Section 03-05 .
  1. Partially raise the vehicle.
  1. Tighten the lower generator bolt to 25 Nm (18 lb-ft).
  1. Connect the generator electrical connector.
  1. Install the battery positive B + cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Install the generator splash shield.
  1. Install the fender splash shield and the retainers.
  1. Install the right front wheel.
3.0L (4V)
Removal
  1. Disconnect the battery ground cable. For additional information, refer to Section 14-01 .
  1. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  1. Remove the power steering line bracket and heater hose support bracket from the generator.
  1. Remove the upper generator bolts.
  1. Remove the right front wheel. Refer to Section 00-02 .
  1. Remove the lower fender splash shield retainers and position the shield out of the way.
  1. Remove the generator splash shield.
  1. Raise the vehicle.
  1. Disconnect the electrical connector and remove the battery positive cable from the generator.
  1. Remove the right subframe bolts.
  1. Remove the lower generator bolt.
  1. Lower the subframe to provide clearance.
  1. Remove the generator.
Installation
  1. Install the battery positive B+ cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Connect the negative battery cable.
3.4L (4V)
Removal
  1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the right side cowl vent screen. Refer to Section 01-02 .
  1. Raise the vehicle and remove right front wheel assembly. Refer to Section 00-02 .
  1. Remove right tie-rod. Refer to Section 11-02 .
  1. Remove accessory drive belt (8620) from generator. Refer to Section 03-05 .
  1. Disconnect electrical harness connector and output terminal wiring.
  1. Remove nut and position engine control sensor wiring (12A581) out of the way.
  1. Remove the two bolts and one stud bolt.
  1. Remove generator from vehcile
May 12, 2009 | 1998 Ford Taurus
Amount of torque on valve cover bolts
it's 12 nM which appears to convert to about 9 foot lbs of torque.... if your torque wrench has nM use that.
Robert
Please take a moment to rate this solution thanks
Apr 21, 2009 | 1997 Plymouth Neon
Locate starter
Starter Motor Removal
  1. sta~us~en~file=ani_caut.gif~gen~ref.gif WARNING: WHEN SERVICING STARTER MOTOR (11002) OR PERFORMING ANY MAINTENANCE IN THE AREA OF THE STARTER MOTOR, NOTE THE HEAVY GAUGE INPUT LEAD CONNECTED TO THE STARTER SOLENOID (11390) IS HOT AT ALL TIMES. MAKE SURE THE PROTECTIVE CAP IS INSTALLED OVER THE TERMINAL AND IS REPLACED AFTER SERVICE.
  1. Raise the vehicle on a hoist. Refer to Section 00-02 .
  1. Disconnect starter cables from starter solenoid.
  1. Remove upper and middle bolt.
  1. Remove lower bolt and starter motor.
Installation
  1. Position starter motor to engine and install middle and lower bolts finger-tight.
  1. Tighten the upper bolt to 20-27 Nm (15-20 lb-ft).
  1. Tighten the lower and middle bolts to 20-27 Nm (15-20 lb-ft).
  1. Connect starter solenoid connector. Be careful to push straight on and make sure connector locks in position with a notable click or detent.
  1. Install S terminal cable eyelet with washer and nut. Tighten to 4.5-6.5 Nm (40-57 lb-in).
  1. Install starter cable nut to starter solenoid B-terminal. Tighten to 9-14 Nm (80-124 lb-in).
  1. Replace red starter solenoid safety cap.
  1. Lower vehicle to floor.
  1. Connect battery ground cable.
Mar 28, 2009 | 1996 Mercury Grand Marquis
2004 Durango 5.7 timing gear alignment
  1. If tensioner assembly is being replaced, install tensioner and mounting bolts. Torque bolts to 28 Nm (250 in. lbs.) .
  2. Retract tensioner if required. CAUTION: The camshaft pin and the slot in the cam sprocket must be clocked at 12:00. The crankshaft keyway must be clocked at 2:00. The crankshaft sprocket must be installed so that the dots and or paint marking is at 6:00.
  3. Place both camshaft sprocket and crankshaft sprocket on the bench with timing marks on exact imaginary center line through both camshaft and crankshaft bores.
CAUTION: The timing chain must be installed with the single plated link aligned with the dot and or paint marking on the camshaft sprocket. The crankshaft sprocket is aligned with the dot and or paint marking on the sprocket between two plated timing chain links.
Feb 13, 2009 | 2004 Dodge Durango
Raymarine E120 GPS Receiver Logo
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
