Question about Magic Chef MCBR440 Compact Refrigerator
Refrigerator motor not working - Magic Chef MCBR440 Compact Refrigerator
  • 906 Answers
Good day,
hopethis link below will solve your problem.
refrigerator
Posted on Aug 03, 2010
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Dispensing ice not working but makes ice fine and water works also
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button
is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your
refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to
troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others
must be repaired by a professional.
1. Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2. Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is
closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not,
this means the motor is frozen.
3. Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Have a nice & a happy day : ).
Aug 15, 2011 | Kenmore Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Evaparator fan motor not working what can be the problem.
The problem could be the defrost timer/control board or a bad fan motor....
Check for power at the motor... if there is power then the motor is bad...
if no power then the controlboard or the defrost timer control is bad...
make sure there is no ice stopping the fan...
heatman101
Dec 21, 2010 | KitchenAid Refrigerators
Refrigerator is not getting cold
the evap fan motor sounds like its not working . replace the fan motor and the defrost terminator .. ..mm
Jul 01, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge not cooling.
If it is an 2 motor unit, just order a charge to the refrigerator... but first check if both motors are running, when making cool.
If it´s the gas charge, the refrigerator must be hot, be careful!
if no one hot, than could have a motor or the protection defect!
Best Regards
Aug 25, 2009 | Refrigerators
Roper Refrigerator/Freezer side-by-side
1. check the motor compresors working touch the top 2. if the motor comp. working 3. touch the high side of the tube of the motor comp. if to hot the freon is ok if not. 4. cut the low side of the motor comp. plug and on start to pumping the motor close the hole of the low side tube using your finger hold 30 sec. and then open if the presures ok 5. the problem is freon
Sep 22, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
163 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
