Toshiba Satellite P35-S609. Bought it used. It started fine when cool but after it ran for a while it would restart only till Toshiba came on the screen and that is the way it stayed until it cooled (like overnight) then it would start up again. Instaaled a good H. D., wifi, and memory. It would update and all, then I tried to use the keyboard and nothing would work.; I tried three different key boards to no avail. I let it run about 24 hrs. and tryed a restart. When I did the screen was not lite but only a third brightness and when the Toshiba came up it went to beeping and kept on until I unpluged it. Now that is all it will dowhen I try to start it. Any ideas??? Thanks, Jim J
  • 6,487 Answers
It seems that this is a overheating issue on your laptop, Because when your laptop is always experiencing overheating that will cause a big damage on the CPU of the laptop that will lead to its not working or booting anymore. So what you can here first is to take the RAM out just to check if that will do any difference and juts put 1 stick of RAM or the old RAM that came with it to check if that will correct the problem, But if not I will really suggest you check the CPU of the laptop and apply a thermal cooling paste on it to improve the cooling system.
Posted on Jun 06, 2010
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
Good luck Hope that helps
May 21, 2010 | Toshiba Satellite P35-S609 Notebook
My toshiba Satellite P35-S609 started not charging. The charge connector seemed not working. I gave it for repair, and the person told that one module which connected the charge chord to the mother board...
Seems a bit odd that the inverter would fail immediately after a repair job that involved the power jack since the inverter is built into the screen housing or lid leaving only a single connector to disconnect then reconnect (aside from the wifi antenna wires) If it is a back-light you can shine a flashlight on the screen in a darkened room and you should see faint images. Use an external monitor to narrow it down to an inverter or perhaps a plug that had not been properly inserted (white one coming from the screen, center above the keyboard) If the external monitor does work then the problem most likely exists after that white connector if it has been inserted properly and has not been otherwise damaged during the repair process previously undertaken. Good Luck!
Jan 22, 2010 | Toshiba Satellite P35-S609 Notebook
Won't stay running
Update the Bios Driver for the computer off of toshibas website and it should fix it, I had the same exact problem!!! And if that doesnt solve the problem you have a bad battery...
Feel free to Email me with questions at newlook_inc@hotmail.com
hope this helps!! Good Luck
Jeremy
Sep 24, 2009 | Toshiba Satellite P35-S609 Notebook
Half of screen flickering
Yes, the probability is that either the circuitry that drives the screen, or the screen itself is on the verge of failing. It is also remotely possible that the backlight is failing. In either case, the likelihood is that a screen replacement is in order. Take it to a computer shop that specializes in Laptop repairs - or call Computer Geeks.
Sep 22, 2009 | Toshiba Satellite P35 PC Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Laptop restarting
Although it could be the hard drive, it could be any number of things as well. First, when the computer starts up, press the F8 key to bring up some options. Select disable automatic restart. This should allow the computer to stop at a blue screen so we can get some information from it. Do this and report back what that information says and we'll go from there. Thanks.
Jun 14, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Toshiba p35-s609 laptop
Sounds like you have diagnosed your own problem to me. Its not the video card or you wouldn't be able to use the monitor, so it has to be a bad switch. If you can remove the bezel covering the switch you my be able to spray some contact cleaner into the switch and get it working again. Removal of most bezels starts with removing the screws on the back side of the lid hinges and lifting the bezell until it un-snaps from the housing.
Good luck. let us know how you make out.
Jan 06, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Computers & Internet Logo
David Payne
David Payne
