Uneven load, washer didnt finish draining or washing,i took the blanket out of washer tried to start it again, it only spun around 2 times then stop and unlocked it self,the delay button was pushed during this process. is there any way to reset it or cancel the delay, also where is the pump filter located?
    Genius:
  • 2,785 Answers
Please provide your model number and make the capacity of your machine
Posted on Apr 10, 2008
Kenmore 400 washer
Try redistributing the blanket evenly around the agitator.
Jun 11, 2017 | Washing Machines
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
I was wahing a load of closes and th leater came up LE and the washing stoped , I took the blanked out and finished. what is the probably? It is new!
This is an LG washer? It was probably an unbalanced load. Heavy blankets can do that.
If the LE code is still there, try this:
Unplug the washer and leave unplugged for 15-20 minutes.
Reach inside and manually turn the drum 2-3 times around.
Plug back in and it should be reset.
Jan 24, 2011 | Washing Machines
Washer full of clothes and water and stopped- how to reset?
According to my experince let the machine stop and complete shut power and try after 10 minutes
Oct 03, 2009 | Maytag PAV2300 Top Load Washer
I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Aug 11, 2009 | Hotpoint First Edition WMA12 Front Load...
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Aug 17, 2008 | Washing Machines
Washing Machines Logo
201 people viewed this question
Top Washing Machines Experts
