Question about Microsoft Office Professional 2007 Full Version for PC
I ms office 2010 setup problem when it setup is half then it want location of proplus.ww now what i do?
    Sergeant:
  • 269 Answers
Upgrading from a pre release version of Microsoft Office 2010. You must first uninstall any pre release versions of Microsoft Office 2010 products and uninstall Outlook Connector..
remove all trace of any 2010 on your hard drive , clean registry also to be 100% sure then install
Mel
Posted on Jun 07, 2010
Setup cannot find the right installation source for ProPlus.WW\ProPlsWW.cab when trying to install Microsoft Office 2016. what can i do???
Hello Hameed, The problem is usually caused by USB Device you used to copy your office 16 files. the solution is to use a different USB device
Apr 02, 2017 | Microsoft Computers & Internet
Setup cannot find proplus.ww owow64ww.cab
How to fix - Setup cannot find ProPlus.WW\ProPsWW2.cab
When you receive the error "Setup cannot find ProPlus.WW\ProPsWW2.cab" it might mean the MD5 checksum the install was expecting and the one on the actual file do not match. Here's how I fixed the issue.
First let me explain in simple terms what the MD5 is. MD5 is an algorithm that is used to verify data integrity. If anything in the file changes the MD5 will also change so it's a way for the program to check the integrity of the file.
The MD5 file is kept in the setup file of the proplus.ww folder. Open it with notepad and find the section that looks similar to the following **the numbers after "MD5 =" is what you need to be concerned with. Also remember that your numbers may differ. **
<LocalCache DownloadCode="{90140000-0011-0000-0000-0000000FF1CE}" SkuComponentDirectory="ProPlus.WW">
<File Id="Office64WW.xml" MD5="899A7D743D01852EBD036B465D1EF181" Size="4685" RelativeCachePath="Office64WW.xml" RelativeSourcePath="Office64WW.xml"/>
<File Id="Office64WW.msi" MD5="43B44C38BE513D9589ECAC7129DDC7C3" Size="3025408" RelativeCachePath="Office64WW.msi" RelativeSourcePath="Office64WW.msi"/>
<File Id="OWOW64WW.cab" MD5="E1E97F01F4292B89953204557A043C7D" Size="23865400" RelativeCachePath="OWOW64WW.cab" RelativeSourcePath="OWOW64WW.cab"/>
<File Id="ProPlusWW.xml" MD5="146CA2B8E1559F81E8DF6A3AED949E2A" Size="17252" RelativeCachePath="ProPlusWW.xml" RelativeSourcePath="ProPlusWW.xml"/>
<File Id="ProPlusWW.msi" MD5="F7DCCD578605F72AEEED775C9EB40AB8" Size="24809472" RelativeCachePath="ProPlusWW.msi" RelativeSourcePath="ProPlusWW.msi"/>
<File Id="ProPsWW.cab" MD5="3EA469E81A6064AE4BEFE4A9ACF36A9D" Size="149278843" RelativeCachePath="ProPsWW.cab" RelativeSourcePath="ProPsWW.cab"/>
<File Id="ProPsWW2.cab" MD5="86BEB0B6A2E76E95E580615185C06B04" Size="197934115" RelativeCachePath="ProPsWW2.cab" RelativeSourcePath="ProPsWW2.cab"/>
<File Id="setup.exe" MD5="4D92F518527353C0DB88A70FDDCFD390" Size="1100664" RelativeCachePath="setup.exe" RelativeSourcePath="..\setup.exe"/>
<File Id="osetup.dll" MD5="FCC38158C5D62A39E1BA79A29D532240" Size="5789544" RelativeCachePath="osetup.dll" RelativeSourcePath="osetup.dll"/>
<File Id="ose.exe" MD5="9D10F99A6712E28F8ACD5641E3A7EA6B" Size="149352" RelativeCachePath="ose.exe" RelativeSourcePath="ose.exe"/>
<File Id="pkeyconfig-office.xrm-ms" MD5="3DCFF1DCDEB1B837EC8F13351C8A92AC" Size="715834" RelativeCachePath="pkeyconfig-office.xrm-ms" RelativeSourcePath="pkeyconfig-office.xrm-ms"/>
<File Id="PidGenX.dll" MD5="7F120AAD20ECAE1EA421083F26611519" Size="1248016" RelativeCachePath="PidGenX.dll" RelativeSourcePath="PidGenX.dll"/>
<File Id="Setup.xml" MD5="" Size="" RelativeCachePath="Setup.xml" RelativeSourcePath="Setup.xml"/>
</LocalCache>
Next you will need to download and install an MD5 checker. I'll leave the process of how to use the MD5 to you to learn but it's pretty simple.
Next run the MD5 checker on the file/s that produce the errors during install. *there may be more than one*
Now there are 2 ways to work around this - If the MD5 on the checker did not match the MD5 in the file it probably means the file is corrupted so your best bet is to download the software again or get another disk.
Another less recommended way is to copy/paste the MD5 from the checker into the file (remember to make a backup of your setup file before) then save it and run the install again. This fools the installation process into verifying that your installation files are all OK.
Good luck!!
Jan 06, 2013 | Microsoft Office Professional 2010
When i install ms office 2007 , after some installation there is a prob to proplus/ww some thing and instslation hangs . what can i do?
If you have a usable activation key for Office you can re-download the entire office 2007 package from C'Net.
For Office 2007 Enterprise: http://download.cnet.com/Microsoft-Office-Enterprise-2007-Trial-Version/3000-18483_4-10742067.html
For Office 2007 Standard: http://download.cnet.com/Microsoft-Office-Standard/3000-18483_4-10651636.html?tag=mncol;4
For Office 2007 Home and Student: http://download.cnet.com/Microsoft-Office-Home-amp-Student/3000-18483_4-10704798.html
Once you download and install there will be an option for activation using your existing activation key.
If this doesn't solve your problem you may be having other issues with Windows or your hardware which would require looking at the exact error within the Event Log (Eventvwr.exe) that will explain what part of the ProPlus.cab file couldn't be copied/installed.
Hope this helps!
Mar 02, 2011 | Computers & Internet
How can i download microsoft 2010 free
First, I want to tell your clearly there is two types of Office 2010 setup one is Microsoft Office 2010 Professional and Microsoft Office 2010 Portable. Also, Microsoft Office 2007 Free Download offline installer setup is available here.
Nov 29, 2010 | Microsoft Office Professional 2007 Full...
I need the file -Office.en-us\dwtrig20.exe for office 2010
contd....
to get all the files download permission you have to only register with email address of u.....then u will get the access code which u have to save the same to use frequently the site.
http://www.gegereka.com
so best of luck to get all the following files to fix MS office installation problem:
a) office 2007 Enterprise\Enterprise.WW\ose.exe
b) office 2007 Enterprise\Office.en-us\dwtrig20.exe
c) office 2007 Enterprise\Office.en-us\DW20.exe
d) office 2007 Enterprise\setup.exe
Aug 13, 2010 | Computers & Internet
Cannot find ProPlus.WW/ProPlsWW.cab.Browse to a valid installatio
The corrupted files are linked to access first. So don't install it in the first phase. Install it in a second phase.
Jul 27, 2009 | Microsoft Office Professional 2007 Full...
MS Office Professional 2007 won't install
It sounds like the disk is damaged, try downloading Office Professional from microsoft website and using the product key supplied with your disk
Feb 02, 2009 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
683 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
