Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My Bissell Pro Heat Select 2X does not pull up the dirt from the carpet into the water. The water just slowly disappears. The first time I used it the water got really dirty. The very next time I used it it worked differently and the water just disappeared until it was all gone. I've only used it a couple times and I don't see where it is working. Has anyone else had this problem?
  • 14 Answers
Inside the plastic suction lid is a little red plastic filter that has to be cleaned out every time you use it because it sounds like your vaccum is not picking up all the hair and debri before you clean the carpet causing the water to be injected into the carpet and disappearing and not filling the tank with dirty water. Steve
Posted on Jun 07, 2010
Testimonial: " Thanks so much for someone finally knowing the problem with my Bissell cleaner. I checked the book that came with it and didn't find this filter mentioned anywhere. I finally have my cleaner back. Love ya!!!!"
I agree thank you SO much!! I have been so frustrated- even on the phone with customer service without any solutions from them. I was ready to throw it in the garbage. Thank you!!!
Posted on Jun 15, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 2x pro heat will not **** water out of my carpet
Try turning the dial on the front that says tools. That solved the same problem for me!!!!
Apr 21, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
336 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
