Question about Zanussi 24 in. DE6850 Free-standing Dishwasher
Wen on wash there is no hot water wen finished
  • Richard Perkins
    Richard Perkins Jun 06, 2010
    Check supply is turned on. If it doesn't get hot at all, it won't usually work. Is it performing a full cycle ?
  • Zanussi Master
  • 43,501 Answers
Wen fell up with water that it,s. It hum
brushes on motor need changing
cheers
Sep 20, 2014 | GE Washing Machines
My washing machine absolutely stinks wen first access water comes out? Why is this pls?
You need to leave it open in between washes. If you have water in it check your drain for a clog.
May 18, 2014 | Washing Machines
My bmw 318ci coupe is havin sum temp sensor problem i think. heatin only blows hot air wen sittin idle and cold wen drivin and the temp gadge needle sits on the blue then sometimes it shoots up like its...
would need head under bonnet to be sure but i suspect a water pump impeller is loose on the drive shaft they are a plasric impeller on a metal shaft and from your description it soulnds like this is the case
Jan 19, 2012 | 2000 BMW 3 Series
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Kenmore Washing Machines
Every now and then when I turn off the car I hear water surging from the motor for about a couple of minutes and the temp gage reads normal? 3.0 Liter V6
sounds like u hav an air bubble in radiator from cold take radiator top off then rev engine to see if it bubbles if it does do this till it stops bubbling then top up wen it cools down then put radiator cap on then check heater gets hot wen warm then this is solved
Aug 24, 2009 | 2005 Lincoln LS
Wont wash
The water level sensing switch could be stuck or not functioning and therefore not cutting off the water when it reaches the correct level and starting the wash cycle.
Sep 24, 2007 | Beko 24 in. D3421F Free-standing...
Zanussi 24 in. DE6850 Free-standing Dishwasher Logo
326 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
