Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
I am connecting my xbox 360 to the web via an xbox wireless adapter through my verizon router. I connect from my xbox to my router and from the router to the web. When I try to connect to xbox live I get a message that a required update is available. When I try to doenload it I get an error and the connection to my router is severed. I get another message that says if the problem persists to go on www.xbox.com/support. Well, here I am.
    Problem Solver:
  • 8 Answers
Possible needs marrying to that product.most need to be flashed by microsoft.if nothing i would recommend a ethernet cable.
Posted on Jun 08, 2010
I have a Xbox 360 Elite with a Xbox 360 Wireless N Networking Adapter attached. Whenever my son plays a game while connected to the home wireless network, no one else in the house can use the Internet...
If other devices can connect once your son is off then it might not be a problem with a router. Try connecting the xbox VIA WI-FI. If the problem persits i would contact your ISP.
May 22, 2017 | Microsoft Wireless Network Adapter Xbox...
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Xbox 360 connection withthe netgear WGR614v9
This is beacuse there is NAT on the router for which you need to open certain TCP/UDP Ports on the router . but firtstly you need to Bridge the Verizon DSl Modem set up the internet connection as per same .
Feb 13, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
How to hookup wireless internet
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 07, 2010 | Video Game Consoles & Games
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
D-link DGL-3420 wont work with Xbox 360 and Airport Extreme
For gaming it is best to use WEP personal, if you are try connecting with a computer. A linksys or cisco router is ideal.
Mar 14, 2009 | D-Link DGL-3420 Wireless Adapter
Xbox 360 wireless adapter not connecting 2 pc
u need a wireless router linsky is about the best out there
Sep 20, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
