Question about Acer Aspire 5500 5570-2609 Laptop
When i turn on the laptop the battery power says 100% then 5min later its 7% then it close down
  • 53 Answers
Your battery is faulty, may be. First unplug the pc, shut it down. THen remove the battery and then clean its terminals with the batery cleaning agents. Also clean the laptop terminals where the battery connects. Now see whether the situation improves or not. If not then you should replace your battery. Its worn down
Posted on Jun 06, 2010
Hi I closed my laptop to put into hibernation mode and then noticed 2 days later that the power light was stuck on and not in hibernation. Upon opening the screen back up nothing happened. No lights, no...
You can try this: Shut the computer down and unplug the power cord from the computer. Remove the battery, then push and hold the power button and sing happy birthday to it. Or wait 15 seconds. Then plug the power cord back and try turning the system on. After it boots up, providing this fixes the problem, you may then replace the battery.
Hope this helps!
Feb 16, 2011 | Dell Studio 1737 Laptop
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
I have a Gateway laptop MX8738, Windows Vista, Dual core. My issue. I always plug my computer into outlet. Do my work. Close down laptop, and unplug from wall. Then about 3 hrs later I plugged in laptop,...
Hi there.
Take the battery out and try to boot on AC power only, if it boots up, turn it back off and reinsert the battery and try to boot again.
If it still suffers from the same symptoms please post back for more advice.
Good luck
Jun 15, 2009 | Gateway MX8738 Notebook
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
VAIO VGN-FS 770W wont turn on
Try to remove the AC power and then the battery. then plug in the power without the battery. Turn-on the Laptop if it starts then slowly put the battery back after it boots in windows. Check if the battery is charging.
Hope this helps.
Dec 01, 2008 | Computers & Internet
Lap top will not start up
take it to service center before you try anything else and the problem gets worst
Nov 22, 2008 | Lenovo 3000 N200 Notebook
Power supply on Gateway Laptop is not recognized, will only run on Battery
YES, take it back.
It should still be on Warranty. Anything that you try to do will void the Warranty.
Note: Power supplies for a laptop are notoriously expensive.
May 13, 2008 | Computers & Internet
VAIO VGNTZ150N Laptop battery runs down when not in use
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Apr 24, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
