Question about Mtd Troy-Bilt Bronco OHV Tiller
Troy bilt mower ran fine then died and now it wont start back. It has fire and a new spark plug. It gets fuel past the filter. It starts if i put a small amount of gas into the intake. Whats wrong? My product is actually a Troy bilt bronco riding mower with 18.5 hp engine
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 46 Answers
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Posted on Jun 06, 2010
Troy Bilt pony will not start
no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
Nov 13, 2013 | Troy Garden
Wont start
I would check for spark, if you have spark put a little bit of carb cleaner in the spark plug hole and see if it fires up and then dies. If that is the case then the carburetor needs to be cleaned. Hope this helps!
Jun 07, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Troy built mower has gas and spark with new plug will not start ,it does not even cough or sound like it is going to start,ran perfect when last ran.
take off the air filter cover and shoot a little gas into the carb.
if it sputters you probably need to have the carb cleaned.
Oct 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-bilt self-propelled w/briggs and stratton 6.75hp after starting runs for 3 or 4 mins. dies out and in 3 mins later will start and do the same thing any suggestions?....thanka abb
Hello. Your carburator is partially clogged up. That said, if you havn't installed a new fuel filter and new air filter this year do so. Also put in a new plug if u havn't lately. Finally get a bottle of a fuel additive called seafoam and pour it into the fuel following the directions on the bottle. J.
Aug 16, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Brand new , won't start, no spark at plug, switch ok
If you know for sure that it's not getting fire, then I would take it back to where you purchased it. It sounds as if it has a bad ignition module.
Jim
Jun 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mtd Troy-Bilt Bronco OHV Tiller  Logo
752 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
