I need a manual for a micronta vox clock 2 - Heating & Cooling
    Brigadier General:
  • 7,191 Answers
To view the online instruction manual, kindly click on this link:
http://support.radioshack.com/support_radios/doc48/48837.htm
Hope this solves your problem. Thanks for using FixYa.
Posted on Jun 06, 2010
Vox
In order to use VOX on your radio you will need a VOX capable accessory OR you can use iVOX which allows you to use talk hands free without an accessory. The instruction for both these features can be found on page 22 in the user guide.
You will need to fill in the "dot" with a "." because Fixya is not allowing insertion of links currently: giantintl dot com/ContentManage-new/manuals/Moto/T65xx.pdf
Keep in mind when using VOX the radio will open up its transmitter with any noise, not just exclusively voices. So if you are in a high noise environment you will not be able to use VOX or iVOX.
Best regards.
Jun 21, 2013 | Motorola TalkAbout T6530R (14 Channels)...
Micronta vox clock 3
The capacitors in these voice alarm and time annunciation clocks leak over time, and degrade the volume control...the only source I was able to find who can completely repair to as-new condition is : "The Electronics Repair Company" in Riverside , CA...951-778-1110...cost is $60.00 labor and cost for the 5 capacitors which need to be replaced...will be restored to like new condition!
Jun 21, 2013 | Radio Communications
Need manual for Radio Shack MICRONTA 63-3003 VLF Metal Detector
Go to http://www.scribd.com/doc/38611721/63-3003-Micronta-VLF-Metal-Detector-Manual
Sep 23, 2012 | Vehicle Parts & Accessories
I need a manual for a Micronta 22-185A multimeter online.
Hi racqbell...
Go to the following webpage and download your user manual for the Micronta 22-185 multimeter.
Please take time to rate me
http://www.pdfph.com/pdf/free-micronta-22-185a-manual/
Aug 18, 2011 | Garden
How do you disable the VOX setting on a Talkabout MR350 2 way radios. I wan to use it with a headset, but do not want VOX on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf You will find the instructions for VOX and iVOX on the bottom of page one, and at the beginning of page 2.
Be certain when plugging in your audio accessory that the radio is turned off. If the radio is left on inadvertently, you would have no control over the VOX settings, it would immediately be in a confused VOX mode.
Also, with most Motorola radios, if VOX begins to occur, turn off the radio, and then re-insert the audio device plug. And in some instances, pressing the PTT on the radio when you are having a VOX occurrence will put the radio back to push-to-talk status.
Best regards.
Feb 19, 2011 | Radio Communications
I am having trouble programing VOX to work on motorola rdu 2020 2-way radios
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Instructions for setting the VOX sensitivity are on page 33.
According to the manual you program the VOX using the CPS (software). Three things which usually cause end-user problems are:
1) Failing to set the sensitivity to a number 1, 2, or 3.
2) Failing to have the radio shut off when plugging in the audio device (headset or earpiece)
3) Failing to use a VOX capable audio device. (Not all headsets and earpieces are VOX capable. Many with inline PTTs are not.)
If these items or instructions do not help, stop by your local Motorola dealer to discuss the problem.
Best regards.
Sep 22, 2010 | Motorola RDU2020 Two Way Radio
Forgot how to get the VOX working on AXU4100
The AX series did not have VOX capabilties. Here is a link to the Owners Manual for the Motorola AX series two-way radio.
http://www.hitechwireless.com/pdf/AXSeriesManual.pdf
Mar 29, 2009 | Motorola AXU4100 (10 Channels) 2-Way Radio
Operating Manual
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps. Ed
Dec 11, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Unwired UFRBS10 2-way radio
I tried to find the user manual but no results mostly of the FRS radios, has a menu wich incluides the Vox feature, please tell me if you have a little face icon, this could be the Vox field to turn on or off. Or tell me what icons you have on it in the menu
Mar 01, 2007 | Unwired UFRBS10 (14 Channels) 2-Way Radio
Heating & Cooling Logo
534 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
