Question about Citizen Eco-Drive JR3080-51L Wrist Watch
Digital time and hand time not the same how do i get the times correct
5 Suggested Answers
SOURCE: I can't get the clock hands to correspond with the digital time.
You must set the "Zero" position for your watch. Follow the instructions at this address and your problem should be corrected.
http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Good Luck
Posted on Jun 23, 2009
  • 2501 Answers
SOURCE: how do i set the hands on my watch to match the
Assuming that you do not have the user instructions for your watch, I suggest that you go to their web site (www.citizenwatch.com) and follow the trail until you get to technical support, at which point you must enter the details that are on the back of the watch.
Posted on Jan 04, 2010
  • 2501 Answers
SOURCE: hands do not show same time as digital display
I have a Casio which had a similar problem and had to resort to reading he instructions to align the times!
I presume that instructions for your watch are not to hand but you can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Posted on Mar 20, 2010
SOURCE: the analogue hands don't show correct time even
Go to "CHR" mode which is the stop watch mode. Pull the mode selector knob, lower right knob. Now all the needles should go 12:00. If not, adjust it using "up" (top right) and "down" (lower left). Select which needles to adjust by top left knob.
I had this watch for almost 10 years and everytime this happened I sent it back for repair. (60 bucks) Finally I open the case my self and the instruction was written on the inside! Hope this helps.
Posted on May 06, 2010
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
I have the correct time set in the watch, the main analog clock shows the correct time, but the UTC analog hands19:00 when the UTC digital time is 12:00. How do I reset the UTC analog hour hands?
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
BTW, I love my Titinimum Skyhawk
Aug 03, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I adjusted the hands when on usin the compass function and when the hands reverted back to the time it was not correct even though the digital time reads just fine..How can I get the watch hands to mimic...
The manual will tell you how to do this. To obtain a copy type "support.tissot.ch/?mod_flashPDF/id_138" into your search engine and this should take you to the manual page for your watch.
Jan 22, 2010 | Tissot T-Touch T33159851 Wrist Watch
I,m in Uk, my watch digital display is correct but not hand displ
you have to go throught the watch menu like your going to change the time. but there is one for the analog when you find it change the time with the start and stop button just like the dig display. you have to hold the button down as the hands scroll.
Jul 11, 2009 | Nixon Insider NIX0033 Wrist Watch
Good Luck
Jun 18, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The digital time and the analog time are not synchronized
Here is complete manual for your watch:
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
If you are not successful with this, maybe it's time to change the battery?
Read manual carefully and you will find out how to recognize: I'ts time to change the battery.
Rate me, please.
Apr 04, 2009 | Tissot T Touch Navigator 3000 T96.1.488.42...
Citizen Eco-Drive JR3080-51L Wrist Watch Logo
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
