Question about Kenmore Elite 45986 Front Load Washer
My kenmore washer drum shakes bad even when the machine is level. Is there a way that I can adjust it myself?
  • 15,935 Answers
It appears your vibration damper(s) has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
My oasis washer when it goes into its last spin it shakes so bad it shuts off
sounds like unbalance load. if it happens alot u may have bad counter weights or bad suspension rods, another solution may be its just not properly adjusted legs to balance machine, check with leveler ad see its its even all around
Oct 18, 2014 | Kenmore Oasis HE 27082 Top Load Washer
The kenmore super capacity 3.5 washer is squeaking and and shaking during the spin cycle. The squeak can be quieted by pushing against the door, but continues as soon as the pressure is released. The...
One of my favorite problems!
We often think that washers are level BUT one of the 4 feet probably requires adjusting downwards so that it really presses against the floor. So-
Remove power.
Press very firmly against one front corner and in towards the centre (sorry- I'm a retired Englishman living in SW France!) and try to rock it. If it moves even the slightest it's the foot at that corner which requires adjusting- with the open-ended spanner which came with the machine (what spanner?)! An adjustable will do and make sure that the foot is adjusted downwards so that it does really press against the floor, almost to the point of raising the corner but not quite.
If not that corner then do the same with the other.
Once adjusted lock all 4 feet by screwing the lock nuts up tight to the base of the washer so they will not move. You should not be able to rock it anymore.
If, after this action, the washer STILL shakes during the spin cycle, I suspect the drum suspension springs/shock-absorbers as being faulty..........................but I would bet that adjustment will cure it!
Good luck,
John C
Feb 09, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer shakes bad during spin
Could also be the drum bearing has collapsed or about to
Apr 28, 2017 | Kenmore Washing Machines
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer vibrating badly
Hi, Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion......
Jul 19, 2009 | LG Washing Machines
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Drum shakes
check to see if you removed the shipping braces refer to your owners manuel
May 25, 2008 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
109 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
