Question about Element Electronics PLX4202B 42 in. Plasma TV
Remote don't work properly
All of a sudden the remote won't work properly .change battery but nothing . Once in a while would change chanel then stop.is there a code that need tobe reprogram? please help. if need a replacement would a universal remote work, can you recommand which brand.
    Champion:
  • 222 Answers
Remove the batteries, open your remote clean the pcb (with cotton ball slightly damped in rubbing alcohol) the one that is painted green as well as the carbon contacts the one behind the remote pads, let it dry and put it back, replace with a new batteries.
Posted on Jun 06, 2010
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
I have a 1996 acura rl and my problem is my remote entry won't work and my cluster light won't shut off and the check engine light came on all at once don't have a clue as to why
remote entry wont work because either remote battery is dead or remote broken.cluster light will stay on if head light stay on could have faulty headlight relay or headlight control unit faulty let dealership check it out.
Sep 09, 2012 | Cars & Trucks
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
All of the sudden the remote control does nothing, won't work at all. What can I do?
try to remove the batteries from remote, if that don't work, unplug main unit from wall for 40 Min., and it will reset back to normal.
Jun 09, 2011 | Bose Audio Players & Recorders
ALL OF A SUDDEN MY REMOTE ISN'T WORKING. I CHANGED A CHANNEL AND NOW NOTHING. CHANGED THE BATTERIES AND TRIED TO RESET THE CODE. STILL NOTHING. HAVE A PHILIP MAGNOVOX. ANY IDEAS?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | RCA RCU403 Remote Control
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Element Electronics PLX4202B 42 in. Plasma TV Logo
110 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
