Question about Frigidaire Heating & Cooling
Frigidaire central unit freezing up leaking
Frigidaire central unit model B3BM-048K-B freezing up and leaking
  • 674 Answers
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Posted on Jun 06, 2010
I bought a new thermostat that requires a C wire. I have a spare wire in the cable that goes from my thermostat to my air handler. It's a Model B3BM-O36K-B Frigidaire model air handler.
At your AHU there may be a terminal block that has a C terminal. If not, you will need to locate C. Your outdoor units control wire should have 1 that connects to the Y signal allowing 24v to pass from Y at the t-stat to a wirenut at the air handler, from that wirenut to the contactor. And C comes from the contactor to a wirenut at the airhandler and to C side of transformer. Common wire colors from o.d.unit are red=24v and White from the o.d. unit, (NOT THE WHITE FROM T-STAT!) is the common. The transformer may also have a tag/sticker that states 24v and common with a color of wire for C. And if the t-stat takes batteries that you need to install, you shouldn't need C wired in. C is there so you don't need batteries, if it has a battery option.
Jun 22, 2015 | Frigidaire Heating & Cooling
B3bm 048k b
You need to program with installation instructions. Press fan & up button @ the same time for a few seconds & go through the installer menu that comes with the thermostat to set it up for heat pump.
Dec 07, 2013 | Frigidaire Heating & Cooling
My central heating is turned on but not warm air is comming out of the vents
It may be zoned and the zones are not enabled or the fan may be gone in the unit. Read documentation, contact installer or call serviceperson.
Nov 05, 2010 | Intertherm P3RA-048K Air Conditioner
My intertherm outside unit is clicking and I can hear a buzzer every so often. When the buzzer goes off the inside lights dim for a second. Model T5BD-048K and serial # T5A060500118. Product p3ra-048k is...
Sounds like the compressor is trying to start but is not. The lights are dimming as the unit is overamping. The buzzing noise is the motor trying to start and failing. The click is the unit going out on it 's safety device, unually an internal overload.
Hope this helps.
Feb 06, 2010 | Intertherm P3RA-048K Air Conditioner
Indoor coils freezing up
You have a low refrigerant (leak) problem or poor airflow due to dirty coils or bad fan motor.
Maybe a combination of all 3.
Check the coils for dirt and lint. Check the fan motor blower wheel for lint on the blades. Check the condensing unit refrrigerant operating pressure. Low side for R22 should be approximately 68 psi, R410 pressure should be approximately 135 psi.
Sep 28, 2009 | Intertherm P3RA-048K Air Conditioner
A/c on house evacuate need to find referigerant leak
if you are saying that your home ac unit is leaking refrisgerant and it is your central air system they have a dye that can be introduced into the system throught its refridgerant intake , if it is a small window unit the odds of fixing it inexpensively are minimal
Aug 31, 2009 | Intertherm P3RA-048K Air Conditioner
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
371 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
