Question about Crosley iJuke (CR17) Shelf System
Can lights in front and bubbles be fixed?
Lights in front and bubbles stopped working?..can they be replaced?
    Champion:
  • 222 Answers
Yes they are
Posted on Jun 06, 2010
Nissan Tiida 2007 model vehicle problem the abs kicks in but no light on the dash. It would kick in while stopping at a stop street or anywhere but intermittently. Brake discs/pads tyres replaced.
try bleeding lines, that can happen with air bubble in check valve, some check valves have a bleeder on them, if not set emergency break on rear it will push fluid back to master cyclinder, for front wheels collapes calipers to push fluid back. first look at mater cyclinder if tilted up you may need to lift front or back to level cyclinder before starting. Have used a baby nose cleaner to remove air bubble from master cyclinder be sure engage break padel when pulling fluid from master cyclinder
Sep 19, 2017 | Nissan Cars & Trucks
The park light in the front and back do not work. If I pressed the break the stop lights will work in the back, If I turned the signal lights it will work in the front and the back but otherwise the park...
verify that you do not have condensation or corrosion in the light sockets. if you do, they sockets need to be replaced. your fuses are blowing most probably due to a faulty ground caused by corrosion (rust).
Nov 01, 2013 | 1996 Ford Windstar
1984 aprice classic, Headlights, Tail lights, Interior lights not working (shut off while I was driving) Brake lights, blinkers still working... I checked fuses and replaced headlight switch... Still not...
Maybe power got cut going to the headlight switch. I think that would be a fusible link coming right off the battery source and going to the switch. Fusible links were used as power distributors before the era of maxi-fuses and power distribution boxes found in today's cars. Just like fuses, the link is designed to break and stop current flow if power demand is too high, like a short. Sometimes they get old and just give out. When the link goes, the wiring insulation may bubble or melt off some, the link may feel uneven or rough. Fusible links can be cut out and replaced with a similar rated new link. If you have no power to the headlight switch, look for a melted fusible link.
Nov 30, 2012 | 1994 Chevrolet Caprice Classic
Signal lights in front won't work
As someone who has had fun with a right rear light panel on a toyota corolla I can sympathize. I went in to the shop and the guy replaced 3 bulbs on mine. Did yo fix the left signal light yet?
Jul 14, 2012 | 1998 Plymouth Voyager
Rear brakes not working proper. I have never liked the brakes on my 2500 chevy pickup. I bought the truck second hand. I have since replaced the front pads twice. The front pads were gone in 18,000...
e-brake pedal should go farther- is either out of adjustment or cable frozen- secondly sounds like only front brakes receiving enough pressure to "activate" properly- bleed all four brakes starting rear pass,then rear drive ,then front pass, then front drive- use plenty of fluid- bleed till fluid is clean without bubbles- will that long at first- this will insure not bubbles and no moisture- if a pro valve dies,you would have more problems- pedal would be really soft,would have both a brake light and abs warning lights
May 15, 2011 | 1995 Chevrolet Silverado 2500
Hi I have a 2001 Mazda Tribute, recently the rear lights and dash board lights have stopped working. the front lights are still working. I Have checked all the fuses I can find and all ok. Can you help...
Double check fuses - replace tail light fuse even if it looks good. If that doesn't fix it, then you have bad headlamp switch (headlamp switch also feeds tail & dash lights)
Mar 23, 2011 | Mazda Tribute Cars & Trucks
How do i replace lights on bubble tubes? They bubble but no lights.
You can order bubble tubes and damaged front plastics from Deer Park Dist (618) 427-3761. Once you get the parts, remove the back of the unit. You will be able to see all the screws which hold on the front plastics. Removing the screws and the plastics to get easy access to the bubble tubes. A long screwdirver is helpful. The magnets in the speakers will grab the screws and the screwdriver from you.
May 12, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Hi the bubbles have stopped working on the right side, what can i do to resolve ?
If both bubble tubes has stopped working on one side then the problem is more likely to be a power issue. Somehow the power is not getting to the tube heaters. On the Wurlitzer OMT there is a small module on the inside of the main door that distributes the power to the various bubble tubes and the page turner (CD models). If the plug is loose or the wire is broken then that could cause one side to be off.
Nov 01, 2009 | Wurlitzer Jukebox 1015 One More Time...
Crosley iJuke (CR17) Shelf System Logo
280 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
