Question about Kenmore 22422 Top Load Washer
After washing Rinse cycle will not work the washer stops and it just hummms when it gets to the rinse cycle you can manuall put it to the spin cycle and it works but the washer will not move once it gets to the rinse cycle
  • Dan Webster
    Dan Webster Jun 06, 2010
    model number?
  • smallblock_3 Jun 19, 2010
    22422 top load kenmore
  • Kenmore Master
  • 8,220 Answers
You probably have a broken drive coupling.after washing Rinse cycle will not work - 1091b32.jpg A very simple repair. What you do is flip up the controls and pop the clips, remove the lid switch connection and get that case out the way. 85c73cafter washing Rinse cycle will not work - 5464918.jpgs=5464918.jpg003967e.jpgYou can then go after the drive coupler.b6901a4.jpg Remove the pump and motor and inspect the coupling for breakage.
More here, Much more here at my Forum
A repair guide for you sir: Direct drive service pamplet
Posted on Jun 19, 2010
  • 35 Answers
First check the program u have fixed.suppose it was correct.u have to check weather led(bulb) is blinking in the rinse mode.its blinking means u have to replace Main controller pcb
Posted on Jun 06, 2010
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
My Kenmore wash cycle stops between rinse and spin
Hi, Does the washer fill in the rinse cycle and then stop? Does it fill and agitate before it stops? If you advance the timer manually past that point, will it finish the cycle?
Question I need to ask in order to help you.
Please let me know so I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Kenmore 22422 Top Load Washer Logo
179 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
