Question about Maytag M6Y12F2A Air Conditioner
There is not any condensed water coming out the back of the unit. Is this a problem?
    Novelist:
    Champion:
  • 246 Answers
The amount of condensate water is related to how much humidity the unit is pullling from the cooling space.
It's possible that water is actually dripping from the unit and it is so little you're not noticing it.
However, if the unit is 'cooling' ok - I would not worry about the lack of water - unless - water starts to drip "inside" from the front of the unit - in which case you will have a problem with the drain.
You could also check the unit and make sure it has a slight tilt to the outside.
Also, you could check and see if the drain hole is clogged up - preventing water from draining.
Hope this helps.
Posted on Jun 11, 2010
Use the dihumidifier
Window air conditioners do not have drains. The water they collect goes to the condenser fan in the back where the water is thrown against the face of the condenser where it evaporates and helps get rid of the air conditioner heat. No dehumidifier is needed. Hope this helps and good luck.
Oct 05, 2014 | Heating & Cooling
Were do i get the manuel for model number ph3 12r03 is the model number were or how do I drain the water and can you send me a manual
Here is the link to the manual:
http://s3.amazonaws.com/szmanuals/b0348062b23e23cd40550b61e1dc5f43
Here are those particular instructions:
Compressor Indicator
The " " icon will light up on the control panel display when the compressor turns on. The " " icon will turn off when the compressor shuts off.
Emergency Condensate Holding Tank
When the room temperature is low and the indoor humidity is high, the air conditioner may not be able to evaporate some of the moisture fast enough. When this happens, the water will accumulate in an emergency condensate tank inside the unit. Once the emergency condensate tank is full, the unit will automatically shut off and the " " will appear on the control panel display. To empty the condensate tank, unscrew the screw plug at the bottom back of the unit. You will need a small pan, approximately 1" high to catch the water coming out of the condensate tank. Once the condensate tank is drained, the unit will begin working within a few minutes. The emergency condensate tank holds approximate
ly 1.5 Liters of water.
Another option is to purchase a small hose from a hardware store that can fit around the 5/8" drain plug on the back of the unit and drain the unit into a gravity drain or larger pan for continuous drainage.
To resume operation quickly, empty the water container according to the following steps:
1. Turn the unit off. Do not move the unit when the water container is full.
2. Place the drain pan accessory under the drainage port at the back of the unit.
3. Remove the screw plug from the drain hole. The condensate water will drain out automatically. When the drain pan is full, screw the screw plug back onto the drainage hole to stop the water flow. Empty the drain pan. Repeat until all the water is emptied.
Once the water container has been emptied, screw the plug back onto the drain hole. Do not allow the
water to drip continuously into the drain pan, as it might easily overflow.
Jul 13, 2014 | Soleus KY-34 Portable Air Conditioner
My unit is not draining water. I can hear fan blades hitting condensation water.
If your unit is installed properly (very slight tilt down in back) no water should come back into the living area. Water is suppose to be splashed up against the outside coils by the fan blade to help draw heat away from the coils, thus improving efficiancy.
Jul 24, 2011 | Haier HWR08XC7 Air Conditioner
Water leaking out of unit, not out of flow tube.
Some models have a hose, some don't , maybe the drain hole it's restricted, condensor normally it's in the back of the unit, you might have to remove one of the side panels.
Dec 23, 2009 | Convair Portable Air Conditioner
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Shuts off after a while i noticed water was coming out with the air do i have to drain this unit
The drain might be backing up. You probably do need to drain the condensate water. The unit should have a small hose at the bottom in the back where the water will gravity drain out.
Jun 19, 2009 | Haier HPAC99ER Air Conditioner
No water
That water is condensate that is removed from the air. If the humidity is low, you will notice much less water coming from the condensate drain line. I would expect to see some water though.
If the unit doesn't seem to cool as well as it did, then chances are it has a leak and has lost its refrigerant charge.
Sep 18, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Maytag M6Y12F2A Air Conditioner Logo
161 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
