Question about Hitachi 60V710 60" Rear Projection HDTV
Blinking red light for lamp
One day my tv doesn't want to have picture,the red light was blinking says on the manual ,it's the lamp we already change it 2x,still the red light keep flashing.What seems to be the problem.I don't have no more warranty it expires last aug.07
  • jmilleradkpm Jun 11, 2008
    I have the same problem with the blinking red light. I have checked the cover and the lamp assembly and it still just blinks. I am not sure however where the switches are to check.
  • testpilot84 Mar 08, 2009
    I've replaced the bulb and need to find the location of the second switch. I found the door switch. I cannot seem to get the red bulb light to stop blinking. The tv had just gone black and the light started blinking. Changing bulb didn't work. My email is testpilot84@hotmail.com. Help. Thank you
I had the same problem at the time light engine discolored. The repair tech was so stumped after replacing the engine, al the tv would do is power on and then of leaving the lamp ligh blinking. I told the tech the the door switch had been very sensitive causing the problem. the tech ended up just disconnecting the switch and shorting the connector on the circuit board. To fix the promblem, the switch is located just behind the door to the left behind a flimsy piece of plastic. Shorting the two wires in the connector on the switch would save a sevice call. other wise it would require a service call to replace the switch.
Posted on Jul 30, 2009
Would you please email me and help me how to fix my blinking red lights.
jcudia1941@gmail.com
than's so much
Posted on Nov 14, 2008
Hello, would you mine helping me ,I donot know where those switches are located
Posted on Apr 10, 2008
    Genius:
  • 1,153 Answers
Do you have an email addr. ?
  • Lashawn Robinson Apr 10, 2008
    This means that either of the two switches are not closed. Either the Lamp Door Switch and/or the Lamp Switch
Continuous blinks
Change the tv projection lamp inside the tv.The tv projection lamp life cycle has ended.U used this tv every day like 3 or 4 hours wright and the tv been in used for like 3 or 4 years already wright?Yes?Than ur projection lamp has die and it life cycle has ended.Change a new projection lamp for the tv than the tv should work again.
Oct 13, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Tv wont turn on Red standby/temp light and green lamp light are both blinking
The tv projection lamp been inside the tv like 1 1/2 or 2 years already,used tv every day like 4 or 5 hours a daily?The Lamp life are ended.Time to replaced the tv projection Lamp.
Dec 20, 2010 | Samsung HL50A650 50 in. TV
No picture no sound will turn on but not off, red light comes on
When the red light is lit press both the menu and device buttons in on the front of the set in together and hold for 5 seconds then record the two digit blink code that will repeat. I am assuming you will receive a 34 error or a 41Error. But let me know what blink code you get and I will assist you.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
KF-50WE620 Green light blinks (no image) lamp light blinks red
Your owner's manual for the television will contain a troubleshooting section that will describe the blinking codes for the various lights, and what they mean.
However, in your case, it probably means the light is burned out.
The bulb on my TV tends to burn out about every 16 months (I watch TV for many hours per day, so your experience may be different). If your TV is still under warranty, I would suggest you contact the store where it was purchased, or contact the manufacturer.
Jun 20, 2009 | Sony Grand WEGA KF50WE620 Television
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hitachi 60V710 60" Rear Projection HDTV Logo
195 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
