Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Operating instructions I have misplaced the manual for my intex saltwater system. I recall having to push and hold the button and then setting the desired range and then pushing the button to set. I cannot get it to adjust.
  • 297 Answers
Http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
press and hold down arrow till it beeps
press and hold up arrow till it beeps
now use up arrow to select hours to run
now down again till beeps
and then up again till it beeps
wait 2-10 minutes for second green light to come on
Posted on Jun 15, 2010
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
Code 88
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Lost manual
I am assuming you have poured in the correct amount of salt. If not post the size of the pool and I can list the correct amount. Now, you will need to set the hours of operation according to the size of the pool which I need to know in order to help more. I will go through the procedure of startup. When you turn the pump on after dissolving the salt in the pool, it will show a code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep. The LED will flash 00. Your keypad is now unlocked. Push the up button to set the number of daily hours of operation according to the size of your pool. Up to add hours, down to remove an hour. If you do not have an owner's manual tell me the size and where you live and I can tell you how much salt to add and hours each day to run.
May 30, 2010 | Intex Automatic Salt Water System for ...
Saltware system from intex won't unlock
I'm not sure exactly what buttons you're pushing but you push the down button until it beeps, then the up button until it beeps. Then you set it. To lock it you push the down button until it beeps, then the up button until it beeps. Hope that helps and I apologize if those are the steps you're already taking.
May 27, 2010 | Intex Automatic Salt Water System for ...
How do i set my salt water generator?
Hold the down button until it beeps, then hold the up button until it beeps. Now its ready to be set. push the up button to the desired amt of time you want the system to run. Once you have the time set, hold the down button until it beeps then the up button until it beeps. Now its locked and ready to go!
May 26, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
How to program the chlorine generator, Intex.
Hold the down button until it beeps, then the up button until it beeps. Now push the up button to the desired number of hours you want the system to run. When set, hold the down button until it beeps then the up button until it beeps. Now the system is locked and ready to run.
May 11, 2010 | Intex Automatic Salt Water System for ...
88 flashes on display screen
Hold the down arrow till it beeps then hold the up arrow till it beeps When you see double zero then set the # of hours you want it to run with the up and down arrows.
Then you will need to lock it in use the down arrow again and wait for a longer beep then the up again till a long beep.
You are set remeber that it will take about 5 minutes for the chlorine light to come on
you can also go to intex.comm and watch the video or read the manual
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
183 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
