Question about Shakespeare Agility Spinning Reel 6825
I have a Shakespeare Stream Seeker reel. The screw for the bail fell out. Do you know where I can find it.
5 Suggested Answers
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
Posted on May 21, 2009
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
absolutely spot on
Posted on Apr 18, 2010
  • 433 Answers
SOURCE: I have a Shakespeare Arsenal
Use your thumb to control the spool speed, the better you get the better your cast will be
Posted on Sep 15, 2010
Ow do I replace shimano Sedona 500fd fishing reel bail return screw fell out
Please find your reel manual here once opened you will find the maintenance, parts and repair section
I hope this helps :)
http://fish.shimano.com/content/sac-fish/en/home/customer-service/reel-instruction-manuals.html
Nov 09, 2016 | Fishing
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
Need Shakespeare 2210 repair manual
Quite likely one of the best fishing reel sites I have seen for servicing reels - your manual is quite likely in this list:
http://schematics.mikesreelrepair.com/thumbnails.php?album=24
Nov 01, 2017 | Sport & Outdoor - Others
Does not flip arm to lock to reel in line
Normally when you **** the bail, the reel allows you to discharge the line with a flip of the wrist. Then when you touch the crank and execute half a turn it releases the bail to lock the line and allow you to reel in. If this action is not happening, then the release pawl is stuck and holding the bail in place. You must disassemble the reel, clean the parts and re-assemble with proper lubrication. Checking the parts for wear replace all worn parts.
Jun 22, 2011 | Shakespeare Agility Spinning Reel 6825
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
Ladyfish fishing pole by shakespeare
try switching sides of the handle by holding the bell and reeling then screw it in on the other side of the real by just reeling in. If that doesn't work then take all the line out and reel in some new line the opposite way.
Aug 06, 2009 | Shakespeare Surf Fishing Rod and Reel...
What do you do with the line before threading it through the eyes
Take the line off the spool in such a way that the line will be caught by the bail after you cast the line. The easiest way to get it right is to raise the bail like you are going to cast the line, thread the eyes, then trip the bail with the handle, as though you were reeling 'em in.
Happy fishing. I'm jealous.
Best regards, --W/D--
Jul 20, 2009 | Shakespeare Surf Fishing Rod and Reel...
How do you cast?
flip the bail(the round rod in front of the reel)hold the line tight with your finger first and cast(make sure you let your finger off the line when you throw the rod forward.
Jul 17, 2009 | Shakespeare Agility Spinning Reel 6825
Shakespeare Agility Spinning Reel 6825 Logo
107 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
