Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to down load to flash drive
My computer is constantly popping up with Virtual Memory too low
have tried to compact and/or delete programs tofree up space but it hasn't helped much. I hav a 4 gb flash drive but don't know how or exactly what to download to it.
    Guru:
  • 1,705 Answers
I've just cut and pasted this from the windows help files:-
To change the size of the virtual memory paging file
  1. Open how to down load to flash drive - shortcutcold.gifComputer Management (Local).
  2. In the console tree, right-click Computer Management (Local), and then select Properties.
  3. On the Advanced tab, click Performance Options, and under Virtual memory, click Change.
  4. In the Drive list, click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, type a new paging file size in megabytes in the Initial Size (MB) or Maximum Size (MB) box, and then click Set. If you decrease the size of either the minimum or maximum page file settings, you must restart your computer to see the effects of those changes. Increases generally do not require a restart.
note.gif Notes
  • To open Computer Management, click Start, and then click Control Panel. Double-click Administrative Tools, and then double-click Computer Management.
  • You must be recognized as an administrator or a member of the Administrators group on your computer and on the computer you are managing to perform this task.
  • You can view or change system properties on a remote computer or a local computer. To access a remote computer, right-click Computer Management (Local), click Connect to another computer, and then select the computer you want to connect to in the list.
  • For best performance, set the initial size to not less than the recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system.
  • Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
  • To delete a paging file, set both initial size and maximum size to zero.
Once you've set your virtual memory to satisfaction. Just plug your usb flash drive in and watch the bottom right hand corner of the screen. You'll see a couple of process messages the last of which will be "your device is now ready".
What may also happen is a window pops up and asks you how you want to view the files on your device and offer a few programmes with which to do it.
If its data for transfer, click on the folder option, its then just a case of dragging and clicking files over to your computer or vice versa.
If you're still not happy, click on to "Youtube" and search for "How to use a USB drive". There are several good video intruction files there.
Posted on Jun 06, 2010
  • 4,281 Answers
For that first remove all temp files from computer.
Press windows key +R key so you can see run you can also see run in start menu.Click on run and type in run "%tmp% without ""then press enter then remove all temp files.Type in "prefetch" without "" then press ok then remove all prefetch files.
Then right click on my computer icon click on property then click on advanced tab then click on settings of performance then click on advanced tab then click on "change" button of virtual memory then click on custom size and set initial size to maximum size then apply and ok.
Also type in run "chkdsk /r" without "" then press "y" in back screen.
Then restart computer then it fix error on harddrive and recover errors.
Then it will work fine.
Also increase RAM memory if your ram memory is less than 1 GB.
You can check your ram memory size in my computer property.
Let me know if you need further assistance.
Thanks for using FixYa.
LOW MEMORY
Hi Yeyek0905,
Good day!
I understand that your computer is running on Low memory.
If you have budget, it would be best to upgrade your RAM but then you may try the following solutions below:
For Low Virtual memory on Windows XP:
1. Click Start, then open the Control Panel.
2. Select Performance and Maintenance, and then click System.
3. Click the Advanced tab.
4. Under Performance, choose Settings.
5. Click the Advanced tab.
6. Under Virtual memory, click Change.
7. Under Drive [Volume Label], click the drive that contains the paging file (virtual memory) settings that you want to change. In almost every case, this will be your C: drive.
8. Click to select the "System managed size" option, then click Set.
9. Click OK three times and restart your computer
For Low Virtual memory on Windows Vista and windows 7:
1. Click Start, then open the Control Panel then select on Systems.
2. Click on advanced tab and select on settings for the performance option.
2. Select o the advanced tab then check on Virtual Memory(Change).
Uncheck the "Automatically manage paging file size", and select 'Custom Size'.
Increased the size based on the Recommended levels+200mb
You may also do the following to free up some space:
1. Delete Temporary files
a. Click on start and type in %temp% on the run option.
b. Delete all your temporary files.
2. Do a disk clean up.
a. Click on Start
b. Accessories
c. System tools
d. Select on disk clean up.
I hope this helps.
Best regards,
Jheycie
Jan 02, 2011 | Computers & Internet
Hi MY laptop is running very slow
For the better performance delete cookies,temp files from the computer.
Uninstall all the unwanted softwares from the computer.
Run disk clean up
  1. Open Disk Cleanup by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking Disk Cleanup.
  2. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. If the Disk Cleanup: Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
  4. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
  5. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer.
.To run disk defragmentation.
1. Open the Start Menu. A) In the white line (Start Search) area, type dfrgui and press Enter.
OR
B) Click on All Programs, Accessories, System Tools, and then on Disk Defragmenter.
Increase the virtual memory of the computer.
How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
This will improve the performance of the computer.
Thanks.
Aug 20, 2010 | Computers & Internet
Low virtual memory and slow loading
Go back into the virtual memory settings, change the settings using the custom size adjustment.
Change the initial size to 650 and the maximum size to 1200, make sure nothig else is checked and click set and then ok and exit out of all windows and reboot the mechine. let me know what happens and if the bubble popup disapears. cheers.
Mar 25, 2010 | Computers & Internet
I am receiving constant messages about my PC's virtual memory being low. How do I correct?
Hello.
Try freeing up some hard drive space,delete unwanted programs and files.
Go to programs,system tools and run disc clean up.after that run disc defragment.Defrag may take awhile.
This will clean up your hard drive and put it back in order.
reboot pc when done.Should get some memory back.
Jan 14, 2010 | Microsoft Windows XP Home Edition
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Nov 02, 2009 | Gateway Essential 500 PC Desktop
Programs are low to load up
your ram is low....i have a couple of solution just try
1) go to my computer properties and here go to advance tab and set system for best performance..
2) in advance tab there is button to adjust virtual memory..just increse memory manually (note: value must be less then RAM memory)...
restart system and then try to ur programe
Mar 23, 2009 | Image Line FL Studio 8 XXL Full Version ...
Everytime we initialize the internet an error pops up
Go to the control panel, add/remove programs icon. Open it and find Internet Explorer. Click on it and select "Repair". This could fix your problem.
Feb 09, 2009 | Microsoft Windows XP Home Edition
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
Solution.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Low virtual memory
Virtual memory means you're running out of memory, so it's using your hard drive storage as memory. This is slow. This is an indication you: Have too little memory and need to run fewer programs or install more memory; and also increase the size of your virtual memory, which will also make your disk space tighter. If you are really pinching the computer that badly, you may want to consider buying a new laptop altogether -- the prices have come down a -lot- just in the 2 1/2 years since you bought that. Anyway, to work around the immediate problem:
Your Gateway came with Windows XP Home Edition. Click Start: Control Panels. See if you can find the Performance control panel, possibly by switching to "Classic view." In there, look for the memory tab. Find the virtual memory section. It may be set to "Let Windows decide." change it to at least 1000mb.
You can get a bigger hard drive (after buying an external case to move stuff over) and upgrade your memory to as much as 1.25gb; but you may find those purchases to not be sensible relative to the price of a new laptop. Memory is cheap and relatively easy; the hard drive is more difficult and will set you back at least $100 if you do it yourself.
Dec 05, 2008 | Gateway 7210GX Notebook
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
107 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
