Question about Hotpoint Aquarius WF000 Front Load Washer
Bearing making terrible noise when spinning is it easy to replace?
  • 35 Answers
No ...its not easy to replace..there will be a problem in oil seal also.so that only water can go inside the bearing its better to replace a both oil seal and bearing
Posted on Jun 06, 2010
3 Suggested Answers
Lumpy816
  • 246 Answers
SOURCE: ensignia maytag washer noise
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Posted on Jul 01, 2008
  • 100 Answers
SOURCE: Indesit wil103 makes LOUD banging noise on spin cycle
may be the weights that balance the drum vave come loose. there are large bolts that attach them to the drum. do not overtighten them as you risk breaking the posts off.
have a look under the lid. if the weights aren't loose check under the machine for the suspension may be disengaged.
indesit technicians will use a torque wrench to ensure the correct tightness of weight bolts.
Posted on Jan 28, 2009
When the washer spins, it is making a terrible loud noise. The washer has always vibrated, but this noise sounds more like a bearing to my husband. It also smelled hot at the end of the cycle. If the...
the noise is a drum bearing, it is pressed on the back of the washer drum, until recently you would have to buy a new drum for around $700.00 but there are a few companies out there selling a bearing kit, just go to EBAY and do a serch for whirlpool duet bearing kit. they are not easy to replace but it can be done by a novice with a few tools and allot of pay chance......GOOD LUCK
Nov 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Sounds like gear or something is stuck in washer
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. To watch a free video on how to check and replace this part go to www.appliancehelponline.com/servicemanual.html this will walk you thru this. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations.
Mar 30, 2010 | Estate TAWX700JQ Top Load Washer
My washer makes aloud noise when on the spin cycle. HELP I Started a load of laundry and it washed fine until the spin cycle. It started making a terrible noise.
sounds like the bearings have worn out at the back,to check this open door and with your hand lift chrome inner drum up and down if you feel like a knocking noise then its bearings,
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
At the end of the spin cycle the washer continues to spin making a terrible noise
agitator bearings or motor is wearing out and will need to be replaced. I suggest repairclinic.com
Jul 06, 2009 | Washing Machines
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Magic Chef CAV2005AWW makes a noise in agitate cycle
Sounds like a problem in the gear case. This would be a transmision replacement.
Dec 07, 2007 | Magic Chef CAV2005A Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
106 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
