Question about Sony Playstation 3 (PS3) Console
PS3 How do i open my ps3?
    President:
  • 1,194 Answers
Visit this link and there you will get a video on how to open your ps3.
But this is to inform you that opening ps3 will void the warranty.
Good Luck and have a nice day.
Posted on Jun 06, 2010
My ps3 160gb will need assistance how can i open it???
A PS3 can be opened rather easily, but if your PS3 is newer, or still has a warranty on it, I wouldn't open the case. If you're unsure of whether you still have a warranty on it, you can call 1-800-345-7669 and they will give you instructions. If you open your case, you WILL void the warranty. That being said, here goes:
1. Locate the side of the PS3 with the HDD symbol on it(The left side of the PS3). Above the HDD symbol, there is a sticker that covers a plastic cover. Removing this sticker will void any warranty still on the PS3.
2. Peel off the sticker and gently pry the plastic cover out. There is a recessed area with a screw at the bottom, use a small screwdriver to unscrew it.
3. The plastic cover on top of the PS3 is now loose, and you can slide the plastic cover towards the left side of the PS3(where you just removed the sticker) and lift it off.
4. There are 8 screws holding a second plastic cover down. Unscrew them with a Phillips head screwdriver, and set them aside. Lift the cover straight off, and set aside. You have now opened your PS3, and have access to the Blu-Ray player and other internals.
Good Luck!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Can not keep connection with ps3 using a belkin_f5d5231_4_router
*u need to open the ports for the ps3 *contact the ps3 and get the port number * open the belkin router setup page using 192.168.2.1 in the address bar *then click on virtual server then open ports toa particular ip only for ex:: 192.168.2.10 *after opening the ports assign the same ip in the ps3 *then sure it has to work without any problem
Feb 25, 2010 | Belkin (F5D5231-4) Router
Cannot connect dns error 80710102
Your ps3 cannot connect to your dns server, if your using a router make sure all ports are open for your ps3 google ps3 port forwarding for help.
if you want to manually type it in open command prompt and type ipconfig hit enter
this will show your ip and dns settings plug them into the ps3 network settings and try again.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 error 80010201
this error means that a cable is unplugged or some thing like that: last night, my ps3 got a YLOD and because of that i had to open my ps3 and fix it(using gilksy method(it really works!)), after i reassembled my ps3, I got a 80010201 error and realized that my ps3 doesn't recognize controllers at all(even after i connected them to ps3 using USB cable). anyway, i reopened my ps3 and check all the vires and connections and reasembled my ps3 again, the problem was solved. so if you got the same problem, just open the thing and check all connections and unplug and reinsert all the ribbons. it should fix 80010201 problem.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 disk tray wont open
Try this first: Hold down the eject button for 10 - 15 seconds. this is supposed to work as a manual eject for the PS3. If that does not work, Try Reformatting the PS3 hard drive, youll find the option under settings in the PS3 menu
Don't 4get 2 backup ur stuff first!
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
80010201 Error message appears. Please help..
this error means that a cable is unplugged or some thing like that: my ps3 got a ylod and because of that i had to open my ps3 and fix it(using gilksy method(it really works!)), after i reassembled my ps3 and got a 80010201 error and realized that my ps3 doesn't recognize controllers at all(even after i connected them to ps3 using USB cable). anyway, i reopened my ps3 and check all the vires and connections and reasembled my ps3 again, the problem was solved. so if you got the same problem, just open the thing and check all connections and unplug and reinsert all the ribbons. it should fix 80010201 problem.
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Ps3 wont read disk. warrenty ran out opened it up couldnt find anyproblem what should i do
Like the 360, the PS3 also has problems.  This problem is known as the SoD (spin of death). In this the lens of your PS3 stops working. Sony is the best one that can help for this kind of error. Best to stick with them, or if your retailer has an exchange policy, ask for a new PS3. But my local dealer fixes this up for 125$. But as now you've opened up your PS3, only way to fix up ur PS3 is to go to the local market and try some experts there.
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
My daughter stuck coins into my PS3
Ouch.
whatever you do, dont turn on your ps3.
if your ps3 is in warranty, try to call Sony and tell them about the problem. If they wont accept it, go here.
Its a step by step tutorial on how to open the ps3.
Once open, remove all of the coins.
Good luck with your ps3. hate to see such a piece of machinery get destroyed.
Aug 08, 2008 | Video Game Consoles & Games
PS3 USB Ports
how old is your ps3? if less than a year dont open or it will cancel your warranty.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
