Question about Jenn-Air Ovens
I need to replace baking element on model JE3842VRV. it appears as though all I need to do is remove power from outlet, unscrew the two screws holding the old heating element in place and replace the new element in then replace the screws holding the element in place. Any other actions needed here?
  • Jenn-Air Master
  • 3,051 Answers
Hello there:
By the way that you have described it this is right things that i have learned is be careful taking out the screws i have seen them strip out or break and dont tighten them too much once it is snug turn it 1/4 turn more
also clean the area that it connects to really well so it does not short out the new element and Please do not forgett to unplug the oven ok
hope this is very helpful for you
Best regards michael
Posted on Jun 06, 2010
I Have a whirlpool gold accurate system microwave /oven combo Self cleaning and broiler is not working . Regular oven works . There are no error messages . What is causing this
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
Dec 30, 2015 | Whirlpool Ovens
The heating element on my Frigidaire RBE-97N has cracked and broken. How easy or hard is it to replace it?
I assume it is the bake element. These are very easy to replace. make sure the power is off and you can access the screws from the oven cavity. remove the screws, pull gently on the element. If the wires are long enough you should be able to disconnect them or unscrew the wires from the terminals. reattach the wires to the new element. reinsert it back in place and there you go.
Nov 24, 2013 | Frigidaire Ovens
Difficulty level replacing the bake element Kenmore 911.4088816
this is a 15 to 20 min job for you ,.. turn off the power . remove the screws holding the element and slide it out till the wires or exposed . remove the and install them on the new element .( do not let them slide back in /) reinstall the element and you are done . you have done a good job . mm
Jul 13, 2010 | Kenmore Ovens
My whirlpool electric oven broils but doesnt bake. model rf385pcwn1
Hi
The possibilities are a bad Bake element, a broken wire to the Bake element or a bad control board.
You have to remove the Bake element or to pull the range off the wall to perform the troubleshooting and find out which part is bad.
You have to inspect the wires, then remove the wires from the Bake element and check the element for continuity.
If there is nothing wrong then you have to check for 120VAC between each wire and ground and for 240VAC between the wires while the control calls for Bake. If there is no proper voltage then the control board has to be replaced.
However To remove old element, there are 2 bolts/screws on the back of the oven, attached to the element. There will be a silver bar holding the screws/bolts to the back of the oven.
Remove these screws/bolts with either a screwdriver or pliers by turning to the left.
After unscrewing the bolts, pull element out. It will have the electrical wires attached to it with a clamp on each side. Pull wire clamps up to remove the element.
Remove new element from box. Slide new element clamps up into the wires coming out from the back of your oven. (There will be "legs" to hold the element up from the bottom of the oven. These go on the bottom for support of the element).
Tighten existing screws/bolts onto oven through the holes in silver bracket. Do not tighten too much, just make sure is secured.
Turn electricity breaker on and plug oven into outlet. Turn on to 350 and see if it heats up.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 19, 2010 | Ovens
Bottom heating element burned out. Can I get a new one and how do you replace it?
You will need the model number of the machine, Once you have the model number, you can call a parts store to get the part you need.
When you have the part. Very important! First Turn off the power to the machine at the breaker box or sometimes called fuse box.
There are usualy 2 screws holding the bake element in, Remove them and pull the element out untill you see the end of the element and wires attached to them. NOTE : Go slow. You will see the wires at the end of the element. Just take a look at the new one to see what it will look like. Next, remove the wires from the old bake element, they are either screwed on or cliped on with a spade terminal. Take the old bake element and new element and make sure they match. now put the wires on the new bake element and reinstall. Then you can turn the power back on and test.
Nov 19, 2009 | Magic Chef 9815 Electric Single Oven
How do i change the element on a whirlpool akz452?
Turn the power OFF to the oven. Remove the oven racks. Unscrew the element where it enters the back wall of the oven from inside the oven. Carefully pull the element leads out of their respective holes. Carefully because the wires will be short.
Remove the wires from the element terminals. Place the wires on the replacement element. Reinsert the terminals into the holes and replace the mounting screws. Turn the power back on and bake me a dozen cookies.
Oct 31, 2009 | Whirlpool AKZ159IX Oven
Need to replace baking unit on Hotpoint range
Difficult is a relative question, I don't think it's very difficult though.
**First-Unplug the unit from the wall, or shut off any power to the unit.**
All you should need is a robertson screwdriver, perhaps a philips and slotted depending on the existing screw heads (square,star and flat) Remove the two screws at the back of the element bracket. Once they are removed, carefully pull the element a couple of inches from the oven cavity, there will be 2 wires connected to it. Hopefully the wires will be long enough to allow you to do this from the front, if not you'll need to remove the back panel of the range. If you have wires long enough you can proceed to remove them and install the new element in the reverse procedure.
You may also require a pair of pliers as well to remove/install the screws on the bake element, hold the connector with the pliers, and turn the screw with the driver so as not to twist the connector in a circle and hence ruining your new element.
*Note; inspect the connections of the wires to the element, if they look burnt, cracked, or just barely hanging on, replace them. you'll need to purchase (if you haven't already) a wire stripper/crimper and some new fittings. Make sure the new fittings/connectors are of the "hi-temp" (usually chrome/nickle plated) variety. Regular metal connector's will fatigue in a short time, relative again to how often the bake is used.
hope that helps, let me know if you need any further assistance.
Good Luck :)
Oct 23, 2009 | Hotpoint Ovens
Replacing Bake Element for JT980SK3SS (GE Trivection)
Thank you.
I found it without putting the 3 in the search.
All the screws appear to be 1/4 inch hex head screws.
Feb 25, 2009 | GE JRS06SKSS Electric Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bake element in smaller oven replacement
I always unplug oven or turn off power make sure though it will bite ya and hard after turning power off if you do it at the breaker turn stove top on make sure it don come on remember its 220volts and it hurts open oven door remove all racks.Then remove the screws mounting element to oven pull gently towards you (you may have to lift the front up a little) pull old element out until you see the spade connector (plug ins with the wires attached) remove these should be two of them be careful not to let wires go back into the cabinet put new element in hook wires back up to wires push back into the hole and put screws in turn power back on and test. this can also be done by taking the back off also and doing the same thing in the oven.hope this helps ya
good luck
Dec 07, 2007 | Ovens
Ovens Logo
137 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
