Question about Whirlpool Duet GHW9150P Front Load Washer
Went to start a load last night sound like it was going to run but after a min. the water had not started and then a f70 flash on the screen and now it just beeps when you push start no light just sound
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F70 is a communication error between the Central control unit (CCU) and the user interface. To start with you’ll need to check continuity of the user interface and then check the wire harness connecting the user interface & central control unit. If the drum is not moving then central control unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
I have an Acer Travelmate 5520. Last night while working the screen started to flash and then went totally blank. I powered down and back up again and the same thing happened. The laptop is running but the...
Most likely the inverter module for the lcd screen has failed. If you can hook up your laptop to an external monitor, you will be able to make sure that the rest of the laptop sill functions.
An inverter is a inexpensive part, $10-15 dollars, but requires that the lid be disassembled somewhat to install it
Oct 21, 2009 | Acer TravelMate 5520 Notebook
NO POWER JUST BEEPS F70 CODE
Bad main control or ccu here is a link to the repair manual.
http://www.affordableappliance.com/Download%20Folder/Whirlpool%20Duet%20Washer%20Service%20Manual.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WILL NOT START
sounds like water ingress to either a control module or the coil pack, check all control box locations eg footwells for water and then check the engine bay for loose or naked wires, dry and clean and possibly cover with a plastic bag etc and it should be fine.
Jun 14, 2009 | 2000 GMC Safari
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
2002 starter problem
your battery has a bad connection or is dead. the clicking noise is the starter relay working.
Mar 16, 2009 | 2002 Honda VT 1100 C Shadow Spirit
No Power sometime, Engine Light is Flashing
If fuel filter hasn't been done lately I would start there & if you can, have fuel pressure tested while your at it. You may have tired fuel pump but pressure test will confirm. If you recently filled up somewhere different last time you got gas, I'd also try some "Heet" or similar just incase you got a tank full with some water in it.
Dec 13, 2008 | 1999 Jeep Grand Cherokee
Error code F70 on Whirlpool frontload washer WFW9600
Welcome spammailmd
You said, you tried to use the delayed wash last night but when we went to it this morning we had error code F70. There is a small possibility that the door was not closed properly, but we forgot to check. We opened the door, closed it and restarted it on a non-delayed wash and it started just fine. The manual for the washer is not very descriptive with the error codes, it simply says to restart and if that doesn't work call the repair man (what is this a microsoft windows machine?).
Whirlpool codes:
“F” codes other than F20, F21 or F22
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains,
call for service.
Let me know that it works for you or if you have any questions.
Thank You.
Please remember to leave a rating
Huuum
Oct 11, 2008 | Whirlpool Washing Machines
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
