We have a Dometic A/C unit on our 5th wheel. The fan is on, the compressor kicks in, runs cool with no problem, stays on for 90 seconds and then shuts off. The cycle cuts off short. We think we need a new capacitor. The model number is 57915.541 for the capacitor. Does this sound like it is the problem, where do we find this part to replace it? There are no certified technicians anywhere near where we are for the summer and the only way to get the unit fixed is to take it far away and leave it for days at a dealership. The unit is four years old and we've had this problem almost from the beginning. We told the place we bought it several times and they checked it out and said nothing was wrong.
  • 1,284 Answers
Hi, the problem may be as a result of bad capacitor as you have said but there are also a lot reason why the a/c stays on for some minutes and shut off.
You may indeed be low on freon and the low pressure switch is shutting the compressor down so that it is not damaged.
The compressor may be fine and the low pressure switch have gone bad.
The capacitor you are talking about may be bad.
Your compressor may still have some life left in it and needs what is termed a "hard start" kit. This is a kit for older units that assist them in starting.
Compressor may be bad.
Any one of these things could cause the conditions you are finding. You will need the proper equipment to trouble shoot what the particular problem is since there are no certified tech around you.You will need a set of guages to check the freon level and an ohmeter or multi-meter to check the electrical components. Without these tools, you will be guessing and you may end up replacing parts that are not needed and still have the unit having the problem.
My best guess at this point from what you are saying is that the thermal overload inside of the compressor is activating and shutting the compressor down. This happe when the compressor starts to draw up too much current at start up. If this is the problem, it is possible that you can remedy the problem with a hard start kit.
Take care
Posted on Jun 06, 2010
2005 Jayco 5th wheel-we have been running the ac and it cools great but now and then out of no where the compressor shuts off and the fan stays running. We turn the system off and wait a few minutes and...
When this happens, remove filter at ceiling assy and see if there is frost on evaporator coils/fins. That would cause it to kick out until frost is gone, then kick back in. Get back to me, and I'll give you instructions on what may be causing it.
Aug 30, 2010 | Dometic Rooftop RV Air Conditioner
Not cooling
check the and see if the condenser fan is running. you will find it if you take the top off also check and see if the condenser coil is clean. if it is dirty or the fan under the top is not running it will cause the compressor to short cycle on limits or overload.
May 29, 2010 | Dometic Rooftop RV Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
I turn it on (montana 5th wheel) and it sounds like it's tryin to kick in the compresor that is and the fan comes on and the compressor tries to kick in about every 30 seconds but cannot?? it's about 4...
The compressor is trying to start and cannot because it is broken inside and will need to be replaced. The compressor can be replaced by most anyone that is familiar with working on home central air conditioning units. I have replaced a few compressors for units like yours. Have a professional check it out. It could just be the start capacitor, but usually it is not.
Nov 15, 2009 | Dometic Rooftop RV Air Conditioner
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Brand new Duo Therm won't stay running
You really need an Ammeter to check this problem. Just because it is a brand new unit does not mean that there isn't a problem with it. Is it run off of a wall thermostat or manual controls? The compressor has a thermal overload switch on the top (under the plastic cover) that will take the compressor out of the circuit if it gets too hot. However, if the entire unit is shutting off, there is another problem. Selector Switch? Thermostat? Let me know what kind of controls you have and we can go from there.
Jul 01, 2009 | Dometic Rooftop RV Air Conditioner
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
