Question about Kenmore HE2 Plus Front Load Washer
Dryer worked this morning and now it doesn't. It's getting power because everything lights up, when you hit "start" the motor hums but dryer doesn't turn. Belt is not broken.
  • pirtles Jun 06, 2010
    Thermal fuse has continuity, heating element has continuity. Any other deas?
  • 6,784 Answers
HI. I will need the entire model number that is printed on this unit, if possible. This will allow me to pull up the necessary part numbers and explode diagrams needed. I suspect that the motor may be the likely culprit, but to be sure, you will need to inspect the door switch circuit for damage.I will also instruct you on how to test the motor, as well.
Please post the entire model number, asap...
Posted on Jun 06, 2010
  • 19 more comments
    110.87562
  • Michael Masters
    Michael Masters Jun 06, 2010
    Thank you. One moment please...
    I took the belt off and then turned the dryer on to see if the motor turned and not only did it not turn but it didn't even hum. There was a click click sound though. Don't know what that means.
  • Michael Masters
    OK, let's start with the motor. One you have gained access to the motor, there will be two wire leads connected to the motor. Disconnect the motor's two wire leads from the wiring harness. Set your multimeter to the R x 1 setting. Touch each of the meter's probes to one terminal each. Your motor should show little resistance (a reading of zero, or close to zero).
    Now check the ground connection. Place one probe on the bare metal housing of the motor. Place the other probe on each terminal, one at a time. You should not receive any reading on your meter from this test.
    If your washer's motor fails either of these tests, you will have to replace it.
    Now, if the motor passes the inspection, this will lead to the main control board. There are several control relays located on that board(motor control etc..). You can inspect for possible relay damage, visually, by removing the cover and visually inspecting the board for burn marks at the relay section of the PCB. It is mounted inside the upper right section of the units cabinet. The electronic control interface seems to be working fine. no issues there.
    I didn't check the door switch circuit because I didn't quite know how to get there but the feel of the switch is smooth and the sound of the switch is good with nice crisp clicks.
  • Michael Masters
    Ok, sounds good. I am more concern with the motor and main control board. I suspect that there may be damage located at the main board. Can you locate the origin of the clicking noise when trying to initiate a cycle? Was it originating from the main control board, perhaps?
  • Michael Masters
    I apologize for not mentioning the door switch circuit testing procedure. I will explain it below.
    The door switch assembly may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the unit, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the unit cabinet. When reaching into the unit, be careful of sharp edges on the cabinet and interior supports.Once access is gained, locate the door switch. It typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
    Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
    If the switch does not test as described, it should be replaced.( for three way switch, the test is the same. teat each terminal as directed.
    Yes, the sound did appear to be coming from the board. There's no visible signs of damage like burn marks or anything.
  • Michael Masters
    Ok, if that clicking is indeed coming from the main board, this will be the culprit. Although there is no apparent visible markings or discolorations, the damage is present. Possible relay failure. The clicking at the board is a very strong indicator of the damage I suspected in this location.
    The part number needed will be W10111606(Main Control Board).
  • pirtles Jun 07, 2010
    Okay, thanks. I checked out the motor the way you instructed and it passed all tests. Do I have to replace the whole board or can I just replace the relay if I can find it?
    Oh, another thing. You said there were two wires going to the motor. Well, there was more than two but I assumed the two big red wires (one one each end of the vertical connector) were the power wires. Did I assume correctly?
  • Michael Masters
    Michael Masters Jun 07, 2010
    Yes, you are correct. The main power terminals are usually a good test point.
    Concerning the board repair option:
    The individual components may be hard to locate. I do suppose if you could isolate the failed component, it should be replaceable. This particular board is listed as a non repairable PCB, meaning the entire board will most likely have to be replaced.
    Also, when I connected the belt back up and turned the dryer on the motor did hum. Does that still indicate the board is bad?
  • Michael Masters
    The motor test confirmed that the internal components that make up the motor are fine. This is indeed a board issue(main). Were the test results on the door switch circuit in range?
    I have not tested the switch. It seems fine to the touch and has a good tactile feel and sound. I just wanted to make sure you understood that the "click click" sound it made on the board was not a continuous "click click" it was just two clicks.
  • Michael Masters
    I see. The main board should not click continuously. The initial click should start the motor or drying process. There is a secondary click, but it should only occur when the unit reaches its end time or end of the selected cycle(power down). If possible, i would like to know the door switch results. This will be the last isolation move to confirm board failure.
    A bad or malfunctioning door switch can cause the same symptoms as a malfunctioning main board. It would be wise to rule out the door switch. Once you have confirmed that the door switch is indeed functioning, go ahead and replace the main board.
  • Michael Masters
    Although the door switch may sound good, there may be some issues with contact oxidation or loose wring at the circuit. Use my procedure to help with the electrical circuit testing. This is a very inexpensive part to replace. Lets rule it out before you purchase the main board.
    Okay, I checked the switch. I couldn't figure out how to get the switch out so I tested it with the 3 wire pigtail male connector coming off the switch. A white wire, brown wire (middle pin) and blue wire. There was continuity with the white wire and brown wire and it did go to zero when I pushed the switch in. I could not get any continuity with the brown wire and blue wire in any position of the switch.
    I did find the Tech Sheet taped on the inside of the kick panel and, according to it, the door switch test only mentions the brown and white wire, which did test good. It makes no mention of the blue wire.
  • Michael Masters
    Ok, this will make the decision more comfortable to make. The door switch is essentially functioning as it should, which leads to the main board. This will be the culprit.
  • pirtles Jun 10, 2010
    Well, I replaced the board, turned on unit and it didn't work. I immediately got the F01 code.......for Control Board Failure.
    I went back and double checked all the tests and everything else confirmed good.
    Any other ideas? Do you think I got a bad board?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As everything else seems to be working fine then it seems to be an issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 13 more comments
    can I check continuity on the thermal fuse? It's just two slide on terminals, right?
    are you there?
  • Rylee Smith
    Rylee Smith Jun 06, 2010
    Yes still here, you can check the continuity
    if what I checked is the thermal switch it does have continuity. Does that mean it's still good? If so, where is the heater coil?
    There is two components on the exhaust duct. One looks like it has a two pin connector and the other one (the one I assumed was the thermal switch) has just two fast-on terminals. Did I check the right thing?
    never mind, both components have continuity. Where is the heater coil?
    I mean.......heating element.
  • Rylee Smith
    Please tell me the model no# so that I can provide you with model specific information for your Kenmore Dryer.
    Never mind that either. I found the heating element and checked it's continuity and it's good. Any other ideas?
    The owners manual has Model 110.8756, 8757, 8758.............I can't find the exact model number on the dryer anywhere......which is kind of frustrating.
    You still there? Any other ideas?
    It's model number 110.87562
  • Rylee Smith
    Seems
    that you are in hurry, the humming sound is from the motor. As you have check
    everything else so it seems that the issue is with the motor nothing else, also
    check that if something is stuck in the blower wheel and as I said if
    everything else works fine then it is bad motor that should be replaced.
    Please
    assistance.
    Thanks
    Rylee
    Sorry, I've never used this service. I did not know the response time to expect. If I can turn the drum and motor with my hand and not hear anything unusual in the blower wheel (I'm assuming the blower wheel is turning when I do that) would that indicate nothing is stuck there?
  • Rylee Smith
    Hey...Thats fine no need to be sorry about anything. You are right its turning so it means nothing is stuck and its the motor that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Please post a comment for further assistance.
    Thanks
    Rylee
Why does my dryer not start, but the washer is fine?
Hello Jennifer Christie, thank you for your post!
I see that you have replaced the belt and bearing drum in your Frigidaire dryer but the unit does not start. It sounds like you could be experiencing an issue within the motor or timer. I would recommend having a professional come out to properly diagnose and repair your appliance, to avoid any further unnecessary part purchases. I hope this is helpful. -Matt
Aug 30, 2014 | Frigidaire FEX831CS Top Load Stacked...
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Frigidare dryer aeq6000es2 doesn't spin, humming noise, burning smell
Hello tancrbtt - It sounds like your unit may have one or more problems. Either the belt slipped off the idle pulley and/or dryer belt and needs replacing, a faulty motor or a common failure between control and motor. Consult a professional to accurately diagnosis the dryer and to assist with the repairs.
Feb 12, 2013 | Frigidaire Electric Dryer
Dryer works, then will not start for awhile. Then will work again.
Probably a bad motor. Sometimes you can bring a motor back by lubing it with appliance oil. My phone video of an attempt
If you have the money get another motor. If not then try to lube it is what I would do.
Dec 30, 2012 | Maytag Dryers
Will only work with light amount of clothes in dryer, if medium amount just hums and will not start
With the door open hold in the door switch in and turn the drum while someone hits the start switch, if the dryer starts when you do this you may have a bad motor, what this is doing is "jump starting" your motor winding's. If it doesn't start by doing that then you may have a problem in your belt/idler pulley system.
Apr 21, 2012 | Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My dryer stopped working this morning. The light to the on switch is "on," meaning it's red. But everything else looks dead: The start button doesn't have a light. And, the display panel is...
If it there is power in the system (red light on power swithch),yet the dryer does not run - with a totally blank LED screen (no error message), the controller board may be out. You can snap in a new one (remove the top of the dryer, take picture to make sure you know where the wires go) remove from clips n replace. Only thing, it'll cost you $220 to buy a new one. Try repairclinic.com - if it doesn't work you can return for full refund.
Mar 11, 2011 | Asko T731 Electric Dryer
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore HE2 Plus Front Load Washer Logo
114 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
