Question about Vornado (CR1-0073-06) Fan
Vornado 280SS - Can I remove grill and blades for cleaning? If so how?
gh88keys
SOURCE: vornado 210B floor
You can turn the unit around backwards and find three integrated clips holding the front cover on.I use a flathead screwdriver to disengage the clips and the front cover just slips out.
I use a vacuum and windes on thr blade surface.
saw your question and thought I'd chime in.
Good Luck!
Gregg
Posted on Dec 08, 2008
SOURCE: need to remove gril to clean blade and grill
You can remove it by pressing the clips. I used a flat screwdriver as there was no way my thumb would fit in there. But it worked like a champ with the screwdriver. I pressed two clips and it popped and then I could simply lift the grill away from the fan blades.
Posted on May 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Lakewood WC 8 floor fan; blades need cleaned. How
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
  • 28 Answers
SOURCE: I have a Vornado floor
On the model I have, the front grill just pulls off from the front; there are some tabs that you might need to release by pushing with a small screwdriver from the rear. After cleaning, just align the tabs and push it back in until they click back in and latch.
Posted on Oct 24, 2010
  • 12 Answers
SOURCE: i HAVE A Vornado Type
There are three clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock and one at 6 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shold come off.
I can send pic if needed.
cawicks at g mail . com
Posted on Mar 12, 2011
Need to take appart vornado to clean
It depends on what type of unit you have. There are grill clips on the back of the unit that you will need to depress. Some models have screws that need to be removed in order to remove the grill. If assistance is needed please call us at 1-800-234-0604.
Thank you,
Vornado Helps
Oct 24, 2012 | Vornado Dryers
I HAVE A Vornado Type 630 fan. How does one remove the cover so that the fan blades and circular grill can be cleaned. Tahnk you, Joanna
Feb 14, 2011 | Vornado Circulating Fan
How do I clean mynvornado fan blades
Look along the outer edge, on the back.
Use mild soap and water the clean the blades after removal.
Dec 18, 2010 | Vornado Circulating Fan
I have a Vornado floor f an, the blades iof which are coated with heavy dust. How do I remove the front protective screen to clean the blades.
Oct 24, 2010 | Vornado Circulating Fan
How do I open to clean 600 series vornado floor fan
Look along the back, outer edge of the fan.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill should come off. The blade just pulls off. It only goes on one way (due the the "D" shaped shaft).
Oct 18, 2010 | Vornado Circulating Fan
I want to clean a very dirty Vornado circulating floor fan but I don't see how to get it apart.
Oct 09, 2010 | Vornado Circulating Fan
Need to clean..............how do I get it apart to clean model 280SS Have had this model for quite sometime and it deperately needs a cleaning. THNAK YOU!
There are four clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock, one at 4 o'clock, and one at 8 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shuold come off. The clips are just tabs molded into the grill, don't push too agressively, or the tab will break, and the grill will not latch on as well. Check the Vornado website for more information. They used to have a video about cleaning.
Sep 14, 2010 | Vornado Circulating Fan
How to remove the grill to clean the Vornado fan?
You cannot with the clips... its impossible.. wound up breaking the clips... and STILL cannot get grill off. Don't ever by a Vornado if you cannot clean it!
May 10, 2010 | Vornado Circulating Fan
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've been able to remove the front grill & clean it and the blades, but now I'd like to remove the rear...
It's similar to the 600 and 700 series based on a picture of those compared to the 280b model I have. http://www.vornado.com/product-support/support/faq.aspx
Jul 04, 2009 | Vornado Circulating Fan
Need to remove gril to clean blade and grill
Apr 24, 2009 | Vornado Circulating Fan
Vornado (CR1-0073-06) Fan Logo
967 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
