Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
I have a ASUS laptop. It's not opening the internet when I click on the icon. I check the connection and the internet is connected. I tried resetting to manufactory settings but not exactly sure how to do that. Can someone helpf me?
  • 91 Answers
I don't think you are having a hardware issue. i'm most probably sure that you are either getting a virus problem or a spyware blocking access to internet. First of all, you need to scan your hard disk with a stand alone antivirus scanner. i usually use the trendmicro stand alone or the kaspersky one. since you don't have access on this laptop you need to download it from another laptop and transfer by pendrive. you run the antivirus tool with deep scan to removev all virus. as regards for spy, i suggest the adaware spyremover. again proceed by downloading and transfer to infected pc. it should work. at last,you can check all ip address and resolve conflicts in DNS and gateway. i hope this helps you in fixing the internet issue.
Posted on Jun 08, 2010
While attempting to connect to a lan connection, the computer automatically defaults to the work offline selection. Therefore, I am never able to connect to the internet. I tried turning off the work...
Hello brian _I_kilm, there are (4) four different ways to connect to the Internet.
In the (right "start menu" pane), select the Control Panel shortcut.
Once the next window open; scroll to find,paul7of9_21.jpg Network and Internet,
click on it to open. Next, select to open the "Internet Options." paul7of9_22.jpg
To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button,paul7of9_23.jpg and follow all the instruction carefully.
2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process."
3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present? paul7of9_24.jpg Option is available?"
Select to open, and click on the Connectivity Doctor,paul7of9_25.jpg follow all instructions thereafter.
4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories.
Select to open and check to see if you have the paul7of9_26.jpg [Windows Mobility Center]?
Open the program. There will be a Wireless Network {Turn-on / Off} Switch. paul7of9_27.jpg
  • Important "Always! Click Apply, Ok, and Restart the computer after making changes to the computer."
Did this solution help? If so; "helpful Rating Feedback is appreciated, thanks paul7of9.
Feb 15, 2011 | Toshiba Satellite P105-S6197 Laptop
Asus laptop says it is connected to the internet but it doesnt work . Its not teh router as every other laptop, x box and other wireless devices work fine. it has done this since I bought it a year ago. I...
This may or may not help...i figure what the hell at this point, what have you got to lose. There is the possibility that you picked up malware or a trojan and it has changed the internet settings that will keep you from accessing the internet. I am guessing that all you are getting is the Internet can not connect to page. But if you look at the connection icon, it shows that you are connected to your network....right?
Bring up your home page on your web browser, I am assuming you are using Internet Explorer, but these settings are the same in each browser just in a different area. Now once the window is up, don't worry that you can't connect to the actual page, it doesn't matter, look to the right and click on the drop down menu "tools", scroll to the bottom and choose "internet Options". When this window opens, at the top click on the "Connections" tab. Look at the bottom and choose "LAN settings. Now, only the box that says "Automatically detect settings" should be checked! Everything else needs to be unchecked....period!!
Now, click apply or ok or both and exit. Now refresh the browser page and see if you home page comes up....if it does, then great....do a malware search and destroy with "MalwareBytes Anti-Malware Tool"...you can get it here... www.filehippo.com
Perform a "Quick Scan" only and delete all the infections it finds. If this does not fix the problem....sorry, I tried.
Jul 31, 2010 | ASUS F3E-AP183E T7250/2.0/160/1G/15/VBS PC...
Laptop won't scan wireless
check the wireless physical switch if it's on, check the device manager too if the wireless adapter is enabled..
if the wireless part of your laptop is turned on and still not detecting signal and you are 100% sure that wireless signal is present then update the driver of the wireless adapter of your laptop.. if it's built-in, call the tech support team of the laptop :)
Feb 24, 2010 | Toshiba Satellite A75-S229 Notebook
Cant connect to the internet
go to start and go to control panel,
then click on internet options, click on the advanced tab, and click reset, there you will find connectivity or internet or something, click on the cross which brings more info up, it should bring up atheos ethernet, and atheos wireless, delete/uninstall them both. then try to connect again.. should work.
Feb 20, 2010 | ASUS Eee PC 900HD Netbook
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Can not get wireless connection on asus notebook
Try resetting the network adapter.
On the bottom right hand side of the desktop you will see the wireless icon, right click on that ans click on troubleshoot problems. This will reset the adapter and assign an IP address for your your PC.
When its done try to connect to the internet.
If this advice does not help please post back.
Good luck.
Jan 11, 2010 | ASUS m6n Notebook
I just got my Asus Eee PC 1000H and the first thing I tried to do was to connect to the wireless network in my house but I don't have a wireless network icon. The wireless and bluetooth are both turned on....
I am assuming this has windows xp on it. Go to start settings/control panel then double click wireless network setup. Go through the wizard and go from there. If you need further assistance please let me know.
Thank you,
lee
Nov 13, 2009 | ASUS Eee PC 1000H Laptop
Internet connection
most of the time internet explorer is by default brouser available in window when u install the mozila at end end of instalation process a message comes that take settings from internet explorer u have to click on yes option.
or
u can direct see the connection property or lan seting from internet explorer and copy it in mozila connection setting
Mar 05, 2009 | ASUS Eee PC 2G Surf Notebook
Limited access on internet
Try this link. It contains the common causes of limited connection and some solutions that you can try:
http://www.fixya.com/support/t1662136-limited_access_internet
Feb 12, 2009 | ASUS F3E-AP183E T7250/2.0/160/1G/15/VBS PC...
I can't connect internet even though I have connections appearing
use your other pc ..when connected click on the icon in task bar and select properties...in properties open internet protocol(may have to scroll to it) and check details and write them down.
if its set to obtain ip and dns auto then cancel properties.in the network status box which should still be open click on support.
here youll find ip and dns details..write them down..
boot other pc and once up and running open network connections in control panel.click on wireless icon and select from list(to your left) change settings for this connection.in the properties page scroll to internet protocol and insert the detail ip ...subnet ...default gateway and dns server.(the dns is the same digits as gateway)
you should now be able to connect no prob.
Jan 09, 2009 | HP Pavilion DV5234US Notebook Laptop
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
