Question about Carrier 36KCARMS Air Conditioner
I have a new Carrier HVAC system with a fancy EDGE thermostat. When I turn the system OFF at the thermostat, and set the fan to AUTO, hours later I will find that the fan is running and it's setting on the thermostat is now ON. How can I permanently turn off the fan when the system is off?
  • fixya196 Aug 26, 2010
    Thanks. I understand and this indeed will turn the fan OFF.
    However, it's too bad this has to be done. I like the fact that I can program the fan to run when the thermostat is not calling for heat or cooling when in those modes. But the thermostat should turn off the fan altogether when one turns the system to off; without having to go through this programming exercise each time.
    Someone at Carrier wasn't thinking when they designed this thermostat. During the summer, I routinely turn the HVAC system off when it's not needed. This should shut everything off and not require a programming change.
    Problem Solver:
  • 19 Answers
1. Open the door. 2. Press and hold the buttons underneath the heat and cool setpoints simultaneously (the two bottom buttons on the right) until the screen displays the reset reminders and 01 in the lower right corner. 3. Press the up arrow button until 01 changes to 07 with OF (fan mode) next to it. 4. To turn the fan on, press the rightmost lower button then press the up arrow button until the screen displays ON. To turn the fan off, press the rightmost lower button then press the down arrow button until the screen displays OF (off). 5. Press the done button. 6. Close the door.
Posted on Aug 26, 2010
    Thanks. I understand and this indeed will turn the fan OFF. However, it's too bad this has to be done. I like the fact that I can program the fan to run when the thermostat is not calling for heat or cooling when in those modes. But the thermostat should turn off the fan altogether when one turns the system to off; without having to go through this programming exercise each time. Someone at Carrier wasn't thinking when they designed this thermostat. During the summer, I routinely turn the HVAC system off when it's not needed. This should shut everything off and not require a programming change.
  • HVACPro Aug 27, 2010
    Using the hold feature should work for this.
How to turn hunter thermastat model 44134 on
This question needs to be reclassified with aftermarket programmable home thermostats--not fans.
Hunter 44134
Getting the wiring connections correct to the terminals in the back plate is essential. Understanding better which colored wires do what functions for your particular brand and model of HVAC gear proves essential, too: "That's the rub!"
Unlike the brilliant and wisely-instituted electrical code, a sensible common "code" for HVAC thermostat wires doesn't exist--each brand, and many models represented by such brands--may have their own peculiar wiring color conventions. HVAC techs also have noted the increasing numbers of brands and models in the market these days, as well--thus, they too may resort to online help threads concerning such issues. (Certainly, the wiring conventions for heat pumps differs also from that of a conventional heat/air setup.)
Unfortunately, many of Youtube's demonstrations from HVAC pros prove merely general info concerning HVAC systems--these may prove somewhat useful: Being merely general info, they're often not specific enough always for particular units, though. (This proves keenly true concerning thermostat wiring.)
Always switch off the circuit breaker for your HVAC system before proceeding with wiring. My system is a Goodman heat pump--it uses a five-wire thermostat setup: The 44134 model from Hunter doesn't feature a terminal in the back plate for the "C" wire for that. (The blue wire from my Goodman heat pump is the "Comm" or "C" wire--that's very confusing in it's own way--the "B" terminal on the back plate for the 44134, and most other programmable thermostats, often is used with B-coded wires for other manufacturers' HVAC units--generally, "B" wires for such units are blue, as well--beware of reliance upon wiring colors!)
Hunter's FAQs clearly indicate that the "C" wire connection isn't always necessary, nor appropriate, for their thermostats--their 44134 is one isn't an exception. I twisted on a small, gray wirenut onto end of my blue Comm wire, further securing that better with electrical tape. (Simply wrapping the Comm wire well with electrical tape should prove also sufficient.)
Unless you know your system's peculiar wiring very well (that is, you're likely an HVAC tech), don't try to connect a Comm wire to another terminal on the back plate for the 44134--you'll likely ruin your thermostat (perhaps along with some other HVAC electronics): You may need then to get an HVAC tech out, after all!
As indicated above, don't merely "match" wiring colors (as a woman might for interior decorating or remodeling)!: This proves a continuing and overly common, comical mistake! Prove instead somewhat skeptical of thermostat wiring colors! A Biblical scripture applies: "Be as wise as serpents!" Take your time to get wiring connections right!
I've noted that the 44134 unit relies totally upon 2 AA batteries (not supplied in the package)--those must be in good working order and oriented correctly--otherwise, your thermostat and HVAC system won't function. Furthermore, the control unit may be easily removed from the back plate--thus allowing "easy-chair" configuration--again, HVAC and fan functions will halt immediately--the connected unit proves necessary for continued function.
Hunter also points out (on their packaging as well) that the 44134 (and, many other (if not all) Hunter thermostats) won't work with baseboard heating systems. Hunter's site FAQs prove too sparse--some may prove keenly useful, nonetheless.
I can't yet get my heat pump system to work with Hunter's "always on" fan switch setting--the rightmost "Auto/On" setting for that bottom-mounted switch at the right. Perhaps a jumper wire proves necessary in the back plate terminals--somewhere. (I've noted this also for Hunter's common 44277 model, as well.) I glean perhaps that somehow invoking the "G" terminal proves necessary. As usual, investigation proves warranted.
Definitely note the "Cool, Off, Heat" switch on the bottom left of the unit: Yeah, that's all too easy to forget. The Hunter 44134 doesn't provide any feature allowing automatic switching between heating and cooling--one must choose which function for the thermostat to control. If the switch is set to "Heat," cooling isn't possible--and, vice-versa.
For reference and troubleshooting, keep the manual and install instructions in a safe, memorable, and easily accessible place. Hunter does provide PDF manual versions online--installation instructions prove lacking online though--they're not in the user manual, either. Unfortunately, Hunter doesn't upgrade it's PDF manual versions.
I glean that Honeywell units may prove generally more easily configurable than Hunter units. Nonetheless, configuring Hunter units proves far from impossible, though. Configuring Hunter thermostats prove perhaps not as "intuitive.": The formal user manuals provided by Hunter thus may prove more keenly necessary for their thermostats' configuration.
Getting personal help online from Hunter may prove somewhat difficult (that may have changed recently). A few years ago, I called customer support: A woman answered my wiring question very satisfactorily. (I noted a jumper wire connect to the terminals of my old manual thermostat--she indicated that the jumper proves unnecessary in Hunter units.) Hunter phone support hours prove somewhat limited--they're similar to traditional office hours.
As with most programmable thermostats, the Hunter is a PRC (Chinese)-fabricated general-purpose consumer circuitry device. As such, it's (overly) intended to be wired and configured by the user to provide correct function for many particular and compatible HVAC brands/models. Given the particular installation that may perhaps prove difficult. Given the general-purpose nature of such thermostats, a simple installation sheet of instructions can't always offer sufficient and correct answers.
Without the particulars of your HVAC system and thermostat wiring, it proves very difficult in some cases for Fixya and other DIY sites to provide correct answers. (Most DIYers ultimately do succeed with install and use of programmable thermostats, though.)
"Proust" thanks you for getting this far!: Perhaps some of my particular solutions here do prove useful to some of you--more nit-picking, detailed work and anecdotes (intended for specific brands and models) needs to be offered in this area....
Mar 17, 2013 | Dryers
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
Outside unit runs continuously, even when system is off.
On A/C units, there is a low voltage line that leads to a contactor, which engages to close the high voltage circuit to the condensor unit. Over time, the accual contacts in the contactor can weld themselves together. Try shutting off your furnace breaker but leaving on the one for the outside condensor unit. If it still runs, your contactor probably needs replaced. Contact a licensed electrician or HVAC contractor and tell them you think your contactor is in need of replacement. Is a fairly simple and quick replace, but the contactor itself is not cheap.
Oct 10, 2009 | Ruud Central System Air Conditioner
HVAC issues - A/C blows semi-cold air and Heater won't turn on
hi! there,
there are possible cause in the circuit is the thermostat,since thermostat switch is like a switch of light,when this turn on blower and compressor turn on,if you turn on and no cold your thermostat
is defective.replace thermostat,if run but insufficient cold was feel check the operating current,there is a rated current you can compare it can tell if your freon charged is under charged,this should be done by certified service technician from your service center,have inform from your manual the telephone no. and location have it call.if still under warranty claim it have a nice day.
May 15, 2009 | Heating & Cooling
Carrier Performance Edge Programmable Thermostat
Are you a qualified refridgerator mechanic with an eletrical liscence? If not get someone who is because doing it yourself will not only void the warranty of the unit but will also void your house and contense insurance in the event of a fire.
Feb 13, 2008 | Heating & Cooling
Carrier 36KCARMS Air Conditioner Logo
292 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
