Question about Zebra Z4M Printer
Configuration setting does not save
Hi, i have installed a Z4m printer on a pC but i am unable to save the configuration settings, i change the page layout to 180 but when i click ok and go to check the settings it changes to landscape can you help
    Champion:
  • Zebra Expert
  • 285 Answers
Make the changes on the printer,
save the changes (press twice on setup button).
chek if the driver have "use driver setings"
if you want to use the setings from the printer, you need to change the "use drivers setings" to "use printer setings ( this is to change on the driver)
Posted on May 08, 2008
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
Have a Zebra Z6M label printer. We configure it to settings we need to work. Then all of a sudden we are back to factory defaults at random times. Any idea why this is happening?
Your printer driver will overide the printer settings. Set the printer settings and save them. Then print config by hold the cancel while power on. Verify the settings are saved and correct. Then send a label to the printer and see if the parameters have changed. If they changed then change the printer driver settings to your preferences and try again.
Aug 09, 2010 | Zebra Z4M Printer
I set the printer settings, save. When the printers power is turned off, the saved setting are lost- why?
Check in the Configuration Menu for your "Power on" configuration set. It is most likely set to "Factory Default" Change to your custom set (1,2,3 etc) and save. Make sure you save your set again after you set this (you just changed the config so save it)
Mar 02, 2010 | IBM Infoprint 6500 Matrix Printer
No ip info on menu
There is a tiny button on the print server back plane that you can press with a paper clip. This will print out a label with your IP address information. Get the IP address (hope that the printer is set for DHCP) and enter this into a web browser. This will take you to a web interface that will let you make configuration changes to the print server and printer. If the printer is set to static IP, change the IP address of your PC to be in the same subnet as the printer and then fire up the browser.
The user name for the printer is ADMIN and the password is 1234 by default. You can also download ZebraNet Bridge from Zebra's web site. This application will find your printer on the network and let you install fonts, upgrade firmware, change settings, etc.
Jan 19, 2010 | Zebra Z4M Printer
How do i reset my z4m printer?
  1. Press Setup /Exit button 2 times. A message to save changes will be displayed.
  1. Press the “+” sign 3 times. A message to load the default settings will be displayed.
  1. Press the select button 1 time. The printer will be reset.
  1. Print a configuration label:
    1. Turn off the printer.
    2. Press and hold the CANCEL key while turning the printer on.
    3. Release the CANCEL key after the data light turns off. Verify that it is printing correctly.
  1. Software needs to match the printer driver settings. The software will override printer driver settings in properties of the printer.
Nov 11, 2009 | Zebra Z4M Printer
How do i use the auto configuration facility on a sharp mx-2300n. I have saved the configuration on the server but when I connect to this printer over the network, I only get Factory Defaults under User...
While at the printer settings page of the copier on your PC under printer configuration there is an automatic configuration tab. Once you press this it will ask you to check the boxes with the arrow . The paper is set determined by the copier itself. You may need to check your copier settings to make sure it detects the correct paper in the tray. Also it is not recommended to install this way mainly because if the customer doesn't want to print color they are not able to change the printer condition settings at the individual PCs. So individual install is recommended.
Oct 17, 2009 | Sharp MX-2300N Color Copier
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Setting on the control panel
Have you gone to the " Save Configuration" option in the menu ? Try saving to ALL configuration locations.
Aido
Dec 19, 2007 | IBM Infoprint 6500 Matrix Printer
Configuration settings do not save in 'Permanent' mode
Q#1, is the DPI the same as the other printers? there is also an option in the menu to rescale DPI that could cause the issueprint out a setup label from the printer and compare it to one of the other printers.
May 24, 2007 | Zebra Z4M Printer
Zebra Z4M Printer Logo
484 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
