Question about Emerson Quiet Kool 12GJ14 Air Conditioner
Emerson Quiet Cool sleeve a/c turns on--no cool air.
5 Suggested Answers
roniecon
  • 6826 Answers
SOURCE: Replacement for Emerson Quiet Kool 12jw42k
Oh yes,there are plenty to choose from,you can go larger,if it is a 220 volt,and get better service,it will cool better,and cost less,on electric.
Posted on May 28, 2010
  • 3074 Answers
SOURCE: i have an Emerson Quiet Cool a/c, . It has been in
no as the freon is different. Sorry Tim
Posted on Aug 08, 2010
  • 266 Answers
SOURCE: quiet cool emerson model 12G
Sounds like your filter is coming apart. Take the unit out and wash it with a water hose. Clean it but try not to get water on the switches. Put it back in but do not plug it up immediately let it set for 15 to 30 min. I also use a shop vac to **** excess water ect... out of the unit after i clean it. good luck
Posted on Aug 09, 2010
  • 4 Answers
SOURCE: emerson quiet cool air conditioner
Make sure you do not have it on fan and have it set on cool/cold. Otherwise you may need to have the it recharged by a h-vac professional. Also you can try clean the filters and the compresser/condenser (the part that is out side. Sometimes Dirt can keep your unit from working to it full potential.
Posted on Aug 26, 2011
What would cause my emerson quiet kool air conditioner 10GC13-L to keep tripping the breaker?
It probably has something shorted to ground or the compressor or motors are stuck causing a high amperage problem. The breaker is probably fine but it also could be weak but normally its the compressor or a component has faulted to the compressor. If the unit immediately trips breaker its probably shorted to ground. If the unit struggles to start and a few seconds pass before it trips then it may be a component fault.
Jun 09, 2015 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson quiet cool air conditioner does not through out cool air
Aug 26, 2011 | Emerson Heating & Cooling
My emerson quiet kool Air conditioner is not cooling properly. Does it use freon or is there something else I can do to service this problem?
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working
Jan 07, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson quiet kool wall air conditioner. Should vent be open to remove humidity?
No - opening the vent will allow unconditioned outside air into the space and add to the humidity load.
Think of it like your car's A/C - when you put the controls to "Max A/C" the system recycles just the air inside the car and doesn't use any outside air. When the control is set to normal A/C, some outside (fresh) air is brought in.
The same thing is true for a window A/C unit. Keeping the vent closed will help the unit de-humidify and cool the air more quickly.
Jul 12, 2010 | Emerson Quiet Kool 12NW46K Air Conditioner
May 28, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
Emerson Air Conditioner #10HW42K through wall
First off, my model # is Emerson Quiet Kool 10HW42K. No it is not yet solved, however I am reaching out to a number of sources. Was hoping to get a simple answer since it is not a "repair" problem, but rather a "replacement problem". I am looking for another AC that will fit the original sleeve.
Jul 07, 2008 | Emerson Quiet Kool 10NW16K Air Conditioner
OLD EMERSON AIR CONDITIONER PARTS
Quite sure that's a factory direct part.
Nov 05, 2007 | Heating & Cooling
Emerson Quiet Kool 12GJ14 Air Conditioner Logo
85 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
