Question about D-Link DIR-625 (790069292637) Wireless Router
I can't connect to the internet with dlink router
I cannot connect to the internet with dlink TM-G5240 router. I had set-up the network previously and all ran fine. 3 days ago the connection was lost. I have reset, rewired, and reconfigured. The desktop that is wired to the router doesn't connect to the internet, nor do the wireless connections. I am able to access the router at 192.168.0.1. I have run and rerun the setup wizard to no avail. It tells me that I am connected each time. The if I try to PING 206.190.60.37 it times out after 4 attempts, and I can't PING yahoo.com. Anyone have ideas for me?
  • jdklove18 Jun 06, 2010
    I have tried everything that you said. The only thing that could be off would be the WAN setting. I'm not sure what that would be for Comcast. I never entered this before when I had the system up and working.
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 06, 2010
  • For that if you don't know your internet service provider settings then you need to call them then ask them internet settings for your account.
    Then access your router and WAN settings then if your acccount is with static ip thenh configure static ip subnet mask and gateway and dns servers in router wan settings.
    If it need user name and password for connect internet then configure it as pppoe .
    thanks for using FixYa.
Dlink wbr 2310
change the password with a new one (not the default), then change the ssid with a new one (not the default). then reconnect
Aug 25, 2013 | Computers & Internet
TM-G5240 router is slow
Is it the wireless device or your ISP? Location the same on wireless device? Computer same place? Channel the same? Antenna the same? Cables the same? You will never get what is advertised. That would under perfect conditions and the Max it will work. Figure the miles of cables and equipment between you and the ISP and all the places it could degrade a signal. Try a High location for the device, change channels.
Jan 02, 2013 | D-Link Tmobile Hotspot Tmg5240 Wireless...
Seting router d-link airplus g+ tm 624
You can set up for that dlink router.Do this step.
Click start>open internet explorer and the address URL type http://192.168.0.1 press enter.
Username admin
password leave blank
For setting details click this link to download user manual guide http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
Hope can help you.
Thanks using fixya.
Jul 11, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Ssid network
The SSID setting is part of the DLink wireless setting.
To configure the DLInk wireless/router from new, you may need to connect the DLink wireless/router the laptop with a 10baseT cable, then open your browser and enter the URL address http:/192.168.0.1 The default login = admin, no password required. Unless you have previously altered the default settings.
You should configure the DLink wireless with a different SSID from the default one and set it up with encryption preferrably WAP.
You should also setup a password for the admin login, so to prevent someone from hacking into your wireless/router to change your settings and steal your Internet access.
You would need to setup the wireless card in the laptop to have the same wireless/router settings eg. SSID and encryption.
You can now remove the LAN cable and connect to the Internet by wireless.
All this information is in your manual.
Jan 24, 2009 | Dell Latitude D600 Notebook
D Link DIR 635 router conection internet
Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
Nov 11, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link DIR-625 (790069292637) Wireless Router Logo
279 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
