Question about Kenwood VR-3080
Hi. Apparently I click a button on my receiver remote control and now I hear the speakers super low, like a background sound. It does not matter if is on CD player, Video, etc.. Kenwood VR-3080
  • 757 Answers
It is probably a "soft mute" function. Look for the button that looks like it has a speaker on it and press it twice.
Posted on Jun 06, 2010
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Ga759wjsa, volume button dosen't work
First switch on a radio receiver which has AM ( medium wave band)
and if the remote controls batteries are good then ,,
tune the MW / AM to lowest frequecy and then start pressing buttons of remote control one by one. for each button pressed you will hear a sharp sound and the button you don't hear a sound in the radio speakers is the faulty one.Then open remote control ( that is if you know how to ,you may have to open few screws and also pry open some plastic latches .Best to take help from one of your friend who had already opened some remote control .)
clean contacts of control pad of remote control with Iso- propyl alcohol.also called as IP.use sergical cotton which will be clean enough.claen also PCB with IP.after drying for few minutes assemble it.take care not to tear the rubber control pads and do to use sharp instruments to clean any parts of the remote .
happy hunting
shekar
Jan 09, 2014 | Sharp GA759WJSA Remote Control...
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Nov 07, 2008 | Pioneer SX-315
AVR 132 low sound out put
Google the Samsung codes for your particular model. I did the same thing with one of my Remotes. As for the sound for your AVR. The speaker system on the laptop are not all that good. Click the little speaker icon and try to adjust the sound on your laptop.
Sep 18, 2008 | Harman Kardon AVR 130 Receiver
Cant Hear Dialogue Over the Background Sound
I had the same problem, first you can download the manual online to see how to reset the speakers. next, make sure you have true digital audio input with a fiber optic or like connector. you should see little LED symbols of r/l/c/w/rr/rl etc. If you just see R and L, it is not getting a true signal.
But what worked the best was getting a better, devoted, CENTER speaker, not just a speaker in the center, but one devoted to dialogue.
good luck
Jan 27, 2008 | Yamaha HTR-5740 Receiver
No background music in games such is Battlefield 2
Suggest that some sound in the game set up is at low or on muit. the speakers ar dumb thay willonly play sounds from the pc the speakers do not decide not play some sounds and not others.
Jul 26, 2007 | Logitech X-530 Computer Speakers
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Kenwood VR-3080 Logo
85 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
