Question about Delta Machinery Delta ShopMaster DP350 12" Variable Speed Bench Drill Press, 500-3100 RPM, 1/3 HP
The variable pulley over the motor has come apart. how do I put it back together?
    Problem Solver:
  • 7 Answers
There is supposed to be a snap-ring with covering a cap with a spring that compresses the pulley and holds it together. Maybe one of those pieces has broken or is worn out. Most online repair parts places have an exploded diagram of all the parts and where they go so you can identify a replacement.
Posted on Aug 14, 2010
Cvt gears clash hard to get in and out of gear
no gears in a CV transmission
it is a belt between to variable pulleys
as the one pulley gets smaller ( flanges come together ) the belt pushes the other pulley flanges further apart
if you are slashing gears in is in another part of the transmission /transfer case
Nov 27, 2017 | In Office Equipment & Supplies
How to replace belt on modle #rel4434awd dryer
Unplug machine. Remove lint filter. Remove the 2 phillips head screws under filter. Raise top by pressing in on clips with putty knife or flat screwdriver. Clips are just underneath top in front about 3-4 inches from each corner. Lean top back against wall. Unplug wires from door switch. Remove the two 5/16 inch screws holding front to cabinet. These are located in front about 3-4 inches down from top. One on each side. Lean front forward and lift up. Set front aside. Now look underneath drum and you will see belt. It goes around idler pulley and motor pulley. Study how it is on closely as you will want to install new one the same way. Flex idler pulley towards motor. This will loosen belt so it can be removed. Put everything back together in reverse order. It is easier to take apart than to put back together, so study steps you take appropriately. Hope this helps.
Oct 12, 2017 | Dryers
Drum stopped spinning. I took apart and took out the broken belt. Not positive if thats the only problem. I found a one inch in diameter plastic piece that seems to be broken, also. Not sure how to put it...
The plastic piece maybe the pulley on the end of the motor. Check the motor for a drive pulley it will have grooves in it for the belt. Since you are in there check the idler pulley for ware, the drum support pulleys in the back for ware, and see if you have any glide pads for the front of the drum. When you put it together put the belt around the drum before you put it in. Before you secure the front of the drum put the idler pulley on the belt. As long as you do not end up with extra screws you got it back together right.
Jun 01, 2011 | Dryers
Need pamphlet for Briggs,Stratton Eastern Lawnmower 2007 Took lawnmower apart, cannot find book on how to put it back together.
You must have model numbers to get any real help. If you mean you took the motor apart, you could go to www.briggsandstratton.com/ and download a manual.
Find your model number on your motor and enter on web site.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Variable speed belt issue
Get your model and serial numbers from under the seat. Then go to the MTD website where you can download the owners manual which should show the belt diagram.
May 24, 2009 | Mtd Garden
Fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint TDL14 Electric Dryer
LER6636PW0 drum does not turn
hi fakestar,
here is an exploded view of the dyer, and you can see where the pulley came off.8dd05ba.gifpart number 24 are the pulleys.
another picture is for the belt and the tensioner
1e696ba.gifpart number 53 is the tensioner and part number 56 is the belt.
it just tricky on how to put the belt.
first put the pulley back to its location then slowly insert the drum to the dryer while putting the belt around the drum with the grouve of the belt facing the drum.
have a helper hold unto the drum , in place, then lean underneath towards the motor and put the tensioner to its slot at the flooring, just like in the drawing, then insert part of the belt under the pulley of the tensioner then with your left hand, hold the tensioner pulley and with your right hand, grab the belt which you inserted under the pulley, and bend the tensioner towards the right with your left hand while the right hand is pulling the belt towards the motor until the belt loops to the motor's pulley.
i hope i was able to explain that one.
that is really tricky to put on.
tnx 4 using fixya,
drcool
Oct 10, 2008 | Whirlpool LER5636P Electric Dryer
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Delta Machinery Delta ShopMaster DP350 12" Variable Speed Bench Drill Press, 500-3100 RPM, 1/3 HP Logo
316 people viewed this question
Top Delta Machinery Drills Experts
Are you a Delta Machinery Drill Expert? Answer questions, earn points and help others
