Question about Whirlpool Duet GHW9150P Front Load Washer
Grey rubber seal ripped
How do i replace the grey rubber seal that lines the entire drum ripped?
whats the best way to replace it ?
    Genius:
  • Whirlpool Master
  • 1,474 Answers
Utube will show you how..
Posted on Jun 06, 2010
The grey rubber door seal in our Electrolux EW1080 F has lots of black mould trapped inside it. Is there any way to remove the entire seal to clean it or do you just have to try your best to wipe around...
Don't use eucalyptus oil, because it will damage the rubber, and the smell will linger.
The black mould should be wiped off using a damp soft cloth and mild detergent. Diluted bleach (1 part in 10 parts cold water) can also be used, with care (wear gloves); don't use full-strength bleach, because it can damage rubber and corrode metal. Leave the door and detergent drawer open between washes and overnight to keep air circulating through the machine. This will slow down the regrowth of mould. For further improvement, wipe the seal dry after each use of the machine. If your laundry room remains steamy or damp for hours after washing, improve the ventilation
Jan 31, 2018 | Washing Machines
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
There's this grey powdery substance on the rubber seal of the Duet washer and inside the rubber seal, not so much on my wet clothes. I'm assuming the rubber seal is slowly disintegrating? I checked all...
I would get in touch with a washing machine repair person as I believe what you may have either a bearing disintegrating or the spider, the contraption that holds your drum horizontal and allows it to spin,may be corroding. It's called a spider, it's aluminum, and it's got only three legs but when those legs break, the plastic drum and other expensive things often suffer damage as well.
We had this experience this spring with an Inglis washer which is a sister set to the Whirlpool Duet. If the spider is corroding or a bearing is going, and changed before it breaks, it will likely save you about $600 on your repair bill. Remember to compare any repair cost against the cost of a new unit including the age difference. Washing machines only last 7-10 years now... they just aren't built like they used to be.
Nov 29, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Metal Drum Ripped
$1000 est????? parts are guarrennteed i would def call the manufacture.althoug ive neverheard of hte inner basket "ripping apart" im sure you should have some recouse with the manufacture, the machine new costs that now.did ithe tech give you that est with a straight face???? definatlly call someone else!!!!!!!
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal kenmore 3.8 cu ft he3t king size capacity
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
Inner drum of my 7 year old washer WFD 2460 rattles on spin and seems unsupported. The rubber surround is intact, is it the only means to support the drum? Thanks. J.Reeve
Hi there!
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
Jun 18, 2008 | Bosch Washing Machines
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Jan 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 110 45862404
noavatar_s.png marklfixit
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful.
Jan 24, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
430 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
