Question about Whirlpool 24 in. GU980SCG Built-in Dishwasher
Leaks at bottom of door, badly thru wash and rinse. cleaned everything I can think of. have dishes according to use and care guide
  • Whirlpool Master
  • 3,051 Answers
Hello there
Door seal
First make sure that the entire seal is clean and has no visable tears or rips in it if it does replace it.
also
If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Posted on Jun 06, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
AM14C slight leak at the bottom of the water deposit tank,
I love these machines. Keep it and fix the leak.
If you have a leak. You have to find out where it is coming from. Dripping water from the bottom of tank can be coming from a number of different places and at different times thru out the cycle. The rinse cycle or wash cycle or all the time.
The first place to check is the pump. It will leak during the wash cycle. Especially from the top gasket. This one commonly goes out.
The pump motor shaft seal will leak all the time but will drip from motor, not the tank area. You want to fix this before it ruins your motor bearings or motor.
But since you have a corner machine, the first thing to check is the rear door panel. This is were your door would be if you had a straight thru machine instead of a corner machine. It has teflon guides just like your actual doors and they do leak at times or all the time if the guides are
not sealing. IF food particles accumilate at the bottom of that panel it blocks the water from running back into machine and instead, onto your floor from the bottom of tank areas. This is anther common leak.
The teflon guides should be replaced if they have cracks in them or are brittle and flaking apart. Sometimes they slide down and can be push back up from inside the machine. In either case, you will need to clean all the crud from that back panel edge. Usually thats all I do to fix that leak is just clean it up and push those guides out to outside edge with the tip of my screwdriver to tighten the seal between them and the channel.
Hope that helps!
Jul 10, 2010 | Hobart 40 in. AM14-254 Free-standing...
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Isn't cleaning dishes
Ensure that the arms below the baskets can move freely, dont overload the machine,
1 Have you put tablets into the door!
2 Rinse Aid in door!
3 Salt in bottom of machine if you live in a hard water area!
4 Do you know which cycle is which on the control panel you could just be rinseing everything instead of washing it!
Nov 07, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Dishwasher leaks out front
If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and cause water to spill over out the bottom of th door. Use rinse-aid for better drying performance
May 29, 2008 | Dishwashers
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Whirlpool 24 in. GU980SCG Built-in Dishwasher Logo
235 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
