Question about Roper REX4634KQ Electric Dryer
On 2 consecutive cycles, the dryer stopped in the middle of each cycle. Now, it's not starting at all. Is this a timer problem (M460-G) or is there a reset button in the back of the unit somewhere??
  • Roper Master
  • 2,694 Answers
Usually when a switch is bad it won't work at all again so it's not a reset problem and there isn't a reset switch anyway.you could have a bad motor,when the motor heats up it's overheating and cutting out.when it stops does it start right back up when you press the start button or do you have to wait a while?also when was the last time the dryer was cleaned out?if there's a blockage of some kind it could make the dryer run hotter than normal and it will cut out,also you can cook the thermal fuse or the high limit thermostat located on top of the heater box. first make sure you have 240 volts coming to the dryer,with a meter,put it on volts and from the white wire to the red you should have 120 volts and from the white wire to the black you should have 120 volts,this is where the power cord is connected to the dryer in the rear.if that's correct then unplug the dryer,remove the vent line and remove the back panel,with a meter check the white thermal fuse,pull one of the wires off any switch you're checking and read it out,it's to the right of the duct that the lint filter slides into also while your back there check the thermostats on the heater box on the right hand side.if the thermal fuse was bad change it out,it's a 3392519,this will happen from lint biuld up,now take out the lint filter and the two phillips screws on the top panel,then take out the four screws holding the duct on and clean it out with a vac,also if the vent line is long i use a leaf blower and blow out the vent line to clean it,just make sure the vent outside isn't blocked with a cage or something if it is i would remove it permenently.put the back together and move to the front,with a screw driver pop the top panel up,on each side there's a clip around 2 inches in from the side,just pop the top near the clip and make sure you still have the two screws out that are in front of the lint filter,next there are two 5/16 inch screws one on each side that holds the front panel onto the side panels,remove them ,disconnect the door switch wires and pull up on the front panel and remoe it,vac out the inside of dryer,if you have a shop vac put it on blow and blow out the motor and you can blow all the lint from the back of the dryer to the front so you don't have to remove the belt and drum,put it back together and start it up,let me know what you find,
Posted on Jun 06, 2010
  • Sal De Jun 20, 2010
    if it stopped at the same spot it could be a bad timer,you'll need to mark it and watch it,if it stops try moving the timer by hand past that spot or start it past the spot it stops at and see if it will continue to off,if not it sounds like a bad motor not the timer
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Old whirlpool thin/twin Dryer timer old timer M404-G New timer M460-G how to hook up
The problem as stated is that the new M460-G timer does not have the same pins as the old one (because there seem to be a variety of sub-models under the M460-G name). However, I have successfully (at least to provide the timed heat function) used a different M460-G on my Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, I had to figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also by inspection of a wiring diagram at appliance pros dot com
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
c / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)48146720-bbc3-47da-833c-6d50a0cf5df0.jpg
Sep 06, 2015 | Whirlpool Dryers
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
A / Gas / Org
C / Motor / Wh
BK / Motor / Wh
R / Gas / Org
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
123 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
