Question about Saniflo 002/005/007 Saniplus Toilet with Macerator Series Pump in White Elo
AAV for saniflo.
Can I use an AAV to install my saniplus system. The house vent pipe is 25' from where i have to install the toilet.
    Scholar:
  • Saniflo Expert
  • 115 Answers
You cannot use a cheater, studdor or mechanical vent or an AAV on any Saniflo product. As they are considered one way vents, they only allow air to flow one way. Saniflo pumps must have an 1 1/2" vent pipe vented to the open air, air must flow in and out of the vent pipe at all times, otherwise the pump will short cycle and the solids will not leave the toilet. You will have to flush it several times to get rid of the waste and eventually the motor will go bad. Make sure is vented properly.
Posted on Jul 27, 2010
  • 349 Answers
This system can be put on a studor (AAV ) vent if vent can not be reached.
Any approved vent through Lowes , Home Depot or any plumbing supply house. Are allowable to use per plumbing codes in all states.
Posted on Jun 11, 2010
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a saniflo toilet installed in my attic. The pipe runs accross under the roof and is connected to the sewerage pipe for the bathroom on the first floor. What toilet paper should I - use -2-ply or...
Any brand approved for septic should work well in the saniflow system, but the key is to use as little as reasonably possible and flush as you go. Big wads of any type will compromise the system.
Oct 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo has started to go slow- it now does small pumps - one every 30 seconds so takes 5 minutes to drain the bowl. I'm pretty sure no foreign objects have gone into it as it's only me and my wife...
Typically when solids don't leave the toilet after one flush or if it short cycles like is doing, then is definitely a pressure problem. Is the unit vented via an 1 1/2" vent pipe to the open air? Please disconnect the vent pipe and leave the vent connection open to the room, flush the toilet and check if it makes a difference. Air must flow in and out of the vent pipe at all times so it can work properly. An obstruction on the vent pipe can cause this issue. Also could be calcium build up inside the rim of the bowl. Pour a few cups of vinegar on the toilet tank and then flush the toilet, it should get rid of calcium right away.
Jul 26, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator overflows
Check the vent pipe, most of the Saniflo products require an 1 1/2" vent pipe vented to the open air for air flow purposes. Air must flow in and out of the vent pipe at all times.
Jun 28, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniplus draining in pulses
When you flush the toilet, the Saniplus will turn on and off once or twice, this is normal. If it turns on 3 times or more then could be a problem with venting or the discharge pipe installation may not be properly installed. But when you run the sink or shower it will turn on and off constantly, this is normal. The Saniplus pumps out the water as it comes in.
Jun 20, 2010 | Saniflo & Saniplus& Macerator Pump
When toilet is flushed the pump will continue to pump.
The air breather hole must be kept plugged in the US as odors will emmit through there is left open. I was told that it was only used for European installations. In the US the breather hole mut be kept plugged or seal capped. You must vent the unit using an 1 1/2" vent pipe and must be vented to the open air. As per plbg. codes it should be attached to the main vent stack or all the way through the roof.
Mar 31, 2010 | Saniflo & Saniplus& Macerator Pump
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Describe your Saniflo &
your p-trap is dry . the guy who did it probably didn't vent it properly, and it's being syphined. call him back to fix it.
Sep 15, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo 002/005/007 Saniplus Toilet with Macerator Series Pump in White Elo Logo
961 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
