My Lennox HS22 series split system scroll compressor overheats
My Lennox HS22 series split system scroll compressor gets loud and goes off on internal overload.The condenser fan stays running and seems to be turning at the correct speed.My coil is clean and my filters are new.It will run fine for a while but then overheat. the unit is 19 years old.it is a scroll compressor.
    Scholar:
  • 45 Answers
There couild be a small blockage in the refrigerant piping. This obstruction could be cyling through the system and causing the pressures to increase and decrease which is overheating the compressor. Normally when the compressor is overheating there is not enough refrigerant getting returned to the compressore to keep it cool while running. When it shuts down the the refrigerant equalizes which can return the blockage back to the coil or just simply dislodge it frome where it is hung up. When the compressor returns to its running temp, it turns back on and can cycle that blockage through the refrigerant piping which sometimes it may go thru and sometimes gets hung up and clog the system again. I would have a certified technician come over and hook their manifold to the system which can easily tell them if there is a blockage or he can trace the problem. Do you know what type of metering device is in the coil inside?
Posted on Jun 06, 2010
Testimonial: "Thanks Terry I did refrigeration for over ten years but got out of it 15 years ago...It took a while for my brain cells to click.I didn't think about the blockage which still may be a possibility. My pressures were a little low for my ambient temp so I added some freon now I have a good sweat back to the compressor and it has been working good for the last 3 hrs...the temps outside are supposed to hit the hi 90's and I will keep an eye on my head pressure.it is a split system and I'm getting some sweating at my txv..that is were the restriction usually happens.I used to get a lot of cap tube restrictions in small systems.thanks for the help."
Lennox 10hpb
change run capacitor on fan. or bad fan motor
Jul 06, 2014 | GE Zoneline AZ38H12DAD Split System Air...
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
1990 Dolphin Motorhome Dometic AC problem
If your fan motor is slowing or stopping mid cycle it will cause the compressor to over pressurize. Many compressors have aan internal mechanism that will kick in with a loud whooshing noise, then the Thermal protector shuts the compressor off, cools then restarts. If this sounds familiar, you will need to replace your fan motor before you burn up your compressor...which to be honest may already be irreparbly damaged(sorry). Hoping 4 the best.
Jul 11, 2009 | GE Quiet-Aire Ductless Split System Air...
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Loud noise
It is probably a rotary compressor unit.
They tend to make a start up noise.
Some technicians advocate adding a booster starting device to help the compressor start more quickly, thereby reducing startup noise.
Mar 12, 2009 | Heating & Cooling
New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Jan 24, 2009 | Ruud UAMB Air Conditioner
Lennox heat pump shuts down every 2/3 days
Hi , you may use amphere meter to detect whats goin on to the compressor and component.
Clamp one compressor wire if register exceed the laber amphere of motor motor are stuck or burn/
If not register the clamp meter check the thermal control might burn or lost contact.
Jan 04, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
317 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
