Question about Samsung Digimax D53 Digital Camera
Tried to take a photo and it came up saying card locked, but i had not done anything other than try to take picture.
    Brigadier General:
  • 11,967 Answers
Check the slide switch on the side of the card...should be unlocked.
Posted on Jun 06, 2010
I have a 7303camera it says card locked how can i use it?
I think the USB card is locked. You can slide the card out and flip the little notch up then replace and try.
Jan 08, 2016 | Praktica Cameras
I have an vivitar vivicam s128 when I put my sd card in it says card protected what can I do
Sure you did not lock the card? The little notch should be in the up position as in the picture. Then the manual says you can use SD cards up to 32 Gbyte, but I can't find anything about the cameras compatibility with SDHC cards. So try the camera with a SD card. The used to make SD cards up to 4 Gbyte, but today, even 1 Gbyte cards are SDHC.
1- check Lock
2- Use SD card to see if your camera works with that.
See a 4GB card, only SD, but not for sale anymore.
25340409-k1yyfchjsxnzfpw0twyoxddp-4-0.png 25340409-k1yyfchjsxnzfpw0twyoxddp-4-2.png
Dec 27, 2014 | Vivitar Cameras
SAMSUNG D760 HOW TO DELETE PHOTOS, IT SAYS CARD LOCKED.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 19, 2014 | Cameras
Accidentally switched my sandisk memory to 'lock'
Locking the card simply protects it from writes. It does not wipe out anything that was on it already.
If you're asking about a Memory Stick, there's a switch on the back. Slide it away from the "LOCK" position. If you're asking about an SD card, there's a switch on the side. Slide it toward the metal contacts.
Jan 29, 2013 | SanDisk 16GB Ultra II 15MBS Memory Stick...
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
I cant take delete, or move photos from my sd card, If i try to do anything with the images on the card when its plugged in to my computer a pop up comes up saying 'Cannot move 4267_180627790516_589680516...
is the card lock slider on? look at the card, there is a tiny switch that says in tiny letters lock, is that moved to the lock position? the little slider is on the left side of the card with the SD Logo label
May 07, 2010 | PNY 2GB microSD Memory Card
Says card locked cant take photo
Move the slide switch on the side of the card.
Dec 06, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My samsung s1065 camera is saying "card locked "i have not put a code or anything in it so i dont know why its locked an i cannot take any photos or anything
Remove the SD memory card from the camera. Look for the lock switch on the memory card and slide it away from the "lock" position. Re-insert the SD card and all should be well.
SD stands for Secure Digital and was one of the first memory cards to have a physical security lock to protect your data.
Oct 05, 2009 | Fuji FinePix A500 Digital Camera
I Put my memory card (SD 1.0 GB) in the computer to take photo's from it and in a hurry i pulled it out without safely removing it or anything. now when i turn it on it says 'this memory card is protected'...
It sounds as if something has got messed up on the card
Did you get all the photos off the card that you wanted to? If so, try the following:
Put the card back in the computer. Go to 'My Computer', right-click on the icon for the memory card and select 'Format'. (WARNING - Doing this will wipe any data from the card!)
Once your done, try it in the camera again. Hopefully all should be OK again.
It might also be worth reformatting the card with the camera itself. It shouldn't make any difference, but some people recommend this.
Hope this helps,
Matt
Apr 16, 2008 | Cameras
Samsung Digimax D53 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
